JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 24d Gender: Male Location: Adelaide Posted 22/07/14 03:53 AM Share Posted 22/07/14 03:53 AM On 22/07/2014 at 1:31 AM, Ralph Wiggum said: Good gide J@ On 22/07/2014 at 1:41 AM, ms700 said: thread needs moar gideU guys suck Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486842 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 20d Gender: Male Location: Central Coast Posted 22/07/14 04:06 AM Share Posted 22/07/14 04:06 AM If it's already got the bigger t04z front wheel (compared to the gtx3582r) but in cast form it maybe cheaper to just replace it with an 11 or 7+7 billet wheel rather than sell it and buy a whole new turboFood for thought Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486846 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 25d Gender: Male Posted 22/07/14 04:22 AM Share Posted 22/07/14 04:22 AM Definately consider what Matty said if you get a pro to do it. If DIY I think a bit hard cause I know the TO4Z cast wheel is a bit tight on a GT turbine shaft even thought technically same diameter. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486848 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 3d Posted 22/07/14 05:48 AM Author Share Posted 22/07/14 05:48 AM On 22/07/2014 at 4:22 AM, turbotrana said: Definately consider what Matty said if you get a pro to do it. If DIY I think a bit hard cause I know the TO4Z cast wheel is a bit tight on a GT turbine shaft even thought technically same diameter. On 22/07/2014 at 4:06 AM, MattyP said: If it's already got the bigger t04z front wheel (compared to the gtx3582r) but in cast form it maybe cheaper to just replace it with an 11 or 7+7 billet wheel rather than sell it and buy a whole new turbo Food for thought How do you know if it has the bigger front wheel? I was assured when I bought it, it was the GCG3566 with the t04z front wheel but when I received it, I wasn't sure. It looked almost identical to the standard wheel IMO. I have some pretty nice balancing machines available between work and uni so may be able to have a crack Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486859 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 20d Gender: Male Location: Central Coast Posted 22/07/14 06:38 AM Share Posted 22/07/14 06:38 AM I am pretty sure the t04z compressor is only marginally larger than the gt35r so it would be hard to tell with naked eye unless you had the two lined up. GCG are fairly reputable so I'd believe them. A 7+7 t04z billet wheel is about 250 from eBay If I remember correctly Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486870 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 3d Posted 22/07/14 07:23 AM Author Share Posted 22/07/14 07:23 AM (edited) I never bought if from gcg so only taking the word of the previous owner. Has the ported gate so more then likely is. Yeah I could only measure about a 2mm difference across the front when they were next to each other so wasn't sure really. What would be required to fit the billet wheel. I assume it needs to be balanced again? Edited 22/07/14 07:23 AM by gaz097 Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486878 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 20d Gender: Male Location: Central Coast Posted 22/07/14 07:23 AM Share Posted 22/07/14 07:23 AM Not a larger wheel bud Same wheel so just fitted and balanced yeah Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486879 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 3d Posted 22/07/14 10:11 AM Author Share Posted 22/07/14 10:11 AM Yeah sorry that's what I meant. How much would the balancing cost. Will it compare to a gtx then? Honestly I only want more low end boost and try to get that up to around 25 then taper it down to say 22. MTA750 seem the way to go as ive spoken to a few and they get them spooling crazy early Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486920 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 20d Gender: Male Location: Central Coast Posted 22/07/14 10:57 AM Share Posted 22/07/14 10:57 AM The 750 is comparable to the gtx3582rThe end game is what your goal is,If you put a billet wheel on your turbo it'll be 400+ on 98 and 500 on e85 with correct supporting mods. You'd increase a little in spool. Let me put it to you this way. I have the standard ba turbo with an 11 blade billet wheel and I went 440rwkw at 21psi on e85. If your on a budget and want big hp Go the billet If your after crazy spool and maybe 400 on e85 go the gtx3576r For you with your turbo already it's not worth going a whole new turbo in similar size to yours (gtx3582r/mta750) Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1486938 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 3d Posted 23/07/14 07:45 AM Author Share Posted 23/07/14 07:45 AM Yeah agreed. Emailed gcg today and got some good and bad news. Looks like I don't have the upgraded wheel so it's just a stock turbo with 0.7 housing , jerk assured me it had the bigger wheel. Does give me room to move though Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/2/#findComment-1487105 Share on other sites More sharing options...
