KPM Motorsport Member 968 Member For: 19y 7m 7d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 12/01/15 12:11 AM Share Posted 12/01/15 12:11 AM (edited) On 10/01/2015 at 10:16 AM, Skids4kids said: High flowed with a precision drill bit?Any chance the brass fittings on the E85 Streetfighter pumps could be changed to be compliant to ethanol KPM?It will bring it very close to a true E85 compatible pump.All our fittings are either brass or nickel plated brass.You are correct that brass isnt exactly suited to E85, however has very little short term effects. I would be more concerned with compatabilty liftime of the many pumps that are 500 hour running time limited.With the increasing poularity of E85 and in the interest of total compatabilty we have nickel plated brass fittings now availble.In regards to our High Flow fuel pressure regulators, they are High flowed to specs advertised and graphed on test bench for accuracy at varying fuel pressures vs flow. A drill bit alone will not suffice. Edited 12/01/15 12:12 AM by KPM Motorsport Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/5/#findComment-1522780 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 29d Gender: Male Posted 12/01/15 03:47 AM Share Posted 12/01/15 03:47 AM I've used a set of hardware drills and a black and decker. It does work. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/5/#findComment-1522824 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 1m 6d Gender: Male Posted 30/04/15 02:38 PM Share Posted 30/04/15 02:38 PM (edited) Any low pressure lift pumps around? Edited 30/04/15 02:39 PM by Skids4kids Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/5/#findComment-1542505 Share on other sites More sharing options...
