GeGe6 Donating Members 1,980 Member For: 12y 9m 17d Gender: Male Location: Perth, SOR Posted 08/01/15 08:02 AM Share Posted 08/01/15 08:02 AM Might be s little of thread, but for those interested.VPW. Com, just sent latest specials with this from new E85 intank from Pro Flow. Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1521980 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 7m 11d Gender: Female Location: SA Posted 08/01/15 08:09 AM Share Posted 08/01/15 08:09 AM (edited) On 01/01/2015 at 9:38 AM, Skids4kids said: The 460 pumps with "larger" pot is not by any means a surge solution.Make sure you remove the plastic fitting that is on the return line in cradle or drill it out as much as possible....it has a 4-5mm hole and slows cradle filling and return line operation is hampered with a larger pump.I run a 3/8 plastic line inside my cradle E85 friendly for the return with no fitting at all...hose sits snug in the hole just pushed in there. On 06/01/2015 at 12:41 PM, Skids4kids said: 413rwkw and 13.0 A/F tuned only to 165kmhr....GTX3582 19psi and Herrod pump finished.Had 1500cc injectors and she would not richen up for us.4spd auto stock stall.Surged at 2/3 of a tank also with my tune(350rwkw at 100kmhr)....launch with traction in first and count to 4 then surge time....cradle was draining faster than fuel could be supplied to pump.Sent it back to Herrods as it didn't flow claimed number....Herrod sold it on again new to someone :/....yup!Good for linear tunes or smaller turbos....was quiet though.IF u modified the Herrod system by changing the Venturi and "drilling a bigger hole" or popped off the fitting that is why your candle wasn't filling it up. My understanding was that most Complete cradle replacements do not need modification majority of the time, only modify if u replace pump only. Edited 08/01/15 08:14 AM by Princess Fluffy Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1521981 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 28d Gender: Male Location: @ my laptop Posted 08/01/15 08:17 AM Share Posted 08/01/15 08:17 AM Many people do not understand the venturi affect and proceed to modify to improve 1 area but destroy another 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1521982 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 6m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 08/01/15 11:24 PM Share Posted 08/01/15 11:24 PM (edited) With regrds to many of the posts above and in line with ratters comments, the system need to be engineered to work properly.What this means is you cannot just change a pump, or modify a cradle, to try and improve fuel delivery.By changing one aspect of a fuel sytem , it affects another.eg larger flow pump affects fuel pressure,or drilling / modifying cradle venturi affects the amount of scavenging refill.Our KPM systems are engineered to work correctly in all areas.That is why we supply the Pump and swirl pot assemblyThe correct High flow fuel pressure regulatorand plug and play wiring kit.This gives you a total system that works , correctly in all areas to supply maximum demand per power rating.We now have 3 levels of intank systems that we believe completely eliminates any reason for a surge tank scenario. Streetfighter Fuel SystemsWalbro 460 - up to 450 rwkw Petrol 420-430 E85Streetfighter 600 - Up to 580 rwkw peterol 480 500 E85Streetfighter 920- Up to 850 rwkw petrol 700 rwkw E85All are supplied as a matched complete direct replacemant fit package including :Swirl pot and pump assemblyHigh Flow fuel pressure regulatorPlug and play wiring/relay kitFitmant is straight forward and as per OEM saving on unnecessary labour and modifications.All our systems are Petrol/ E85 compatable utisiing premium components.Our Streetfighter 600 system utises our own KPM300 10,000 rated Petrol/E85 pumps. These are the only rated pumps in Australia at 10,000 hours on E85. Edited 08/01/15 11:34 PM by KPM Motorsport Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522060 Share on other sites More sharing options...
GeGe6 Donating Members 1,980 Member For: 12y 9m 17d Gender: Male Location: Perth, SOR Posted 08/01/15 11:27 PM Share Posted 08/01/15 11:27 PM Have you got prices for each one? Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522061 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 6m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 08/01/15 11:38 PM Share Posted 08/01/15 11:38 PM (edited) On 08/01/2015 at 11:27 PM, GeGe6 said: Have you got prices for each one?BF Mk2-FG All MODELSStreetfighter Fuel SystemsWalbro 460 - up to 450 rwkw Petrol 420-430 E85 $790Streetfighter 600 - Up to 580 rwkw peterol 480-500 E85 $1690Streetfighter 920- Up to 850 rwkw petrol 700 rwkw E85 $2295All are supplied as a matched complete direct replacemant fit package including :Swirl pot and pump assemblyHigh Flow fuel pressure regulatorPlug and play wiring/relay kitFitmant is straight forward and as per OEM saving on unnecessary labour and modifications.BA-BF Mk1Add $200 on all kits. Comes with complete fuel tank. Edited 08/01/15 11:39 PM by KPM Motorsport 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522063 Share on other sites More sharing options...
hobo Member 22 Member For: 17y 6m 3d Gender: Male Location: NSW Posted 09/01/15 02:14 AM Share Posted 09/01/15 02:14 AM KPM, Can you tell me more about the high flow pressure regulator? is it a bosch part or something modified? Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522103 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 6m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 10/01/15 12:51 AM Share Posted 10/01/15 12:51 AM We re-manufacture a Bosch part#.The regulator is carefully enhanced to flow 400 lph reflow capacity, graphed and tested. Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522376 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 1d Gender: Male Posted 10/01/15 10:16 AM Share Posted 10/01/15 10:16 AM (edited) High flowed with a precision drill bit?Any chance the brass fittings on the E85 Streetfighter pumps could be changed to be compliant to ethanol KPM?It will bring it very close to a true E85 compatible pump. Edited 10/01/15 10:18 AM by Skids4kids Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522514 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 28d Gender: Male Location: @ my laptop Posted 10/01/15 10:26 AM Share Posted 10/01/15 10:26 AM people have been using jet drills for years with great success for fine calibration, but knowing the machining facilities available to KPM, I dare think they are using a little more than a set of hardware drills and a black and decker 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/4/#findComment-1522515 Share on other sites More sharing options...
