ratter Member 6,793 Member For: 18y 10m 27d Gender: Male Location: @ my laptop Posted 02/08/14 10:46 AM Share Posted 02/08/14 10:46 AM did you check your fuel pressure at idle Greg? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1489380 Share on other sites More sharing options...
gregaust Member 48 Member For: 21y 7m 4d Gender: Male Location: QLD Posted 08/08/14 01:14 PM Share Posted 08/08/14 01:14 PM I didn't Mick. I fitted the pump in, started and checked was all good. Then fitted injectors and a start up tune. I left the rest to my friends doing the tuning. This is all new to me. Should I check ? Not sure if they did I'd have to ask. Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1491289 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 27d Gender: Male Location: @ my laptop Posted 08/08/14 01:16 PM Share Posted 08/08/14 01:16 PM a pump like that will normally exceed what the pressure reg can control so you end up with higher fuel pressure at low engine speeds, the tuner can tune around this but the fuel trims will also correct it to a certain point, but I believe in having the correct pressure and try to have very little correction 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1491290 Share on other sites More sharing options...
gregaust Member 48 Member For: 21y 7m 4d Gender: Male Location: QLD Posted 08/08/14 08:22 PM Share Posted 08/08/14 08:22 PM Thanks will get it checked and see. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1491314 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y Gender: Male Posted 29/12/14 12:40 AM Share Posted 29/12/14 12:40 AM Something to consider when fitting a 460 pump or similar is to upgrade the wiring feeding it.Most think its the fuel pressure as the major issue when fitting one of these but for me its the factory wires being far exceeded in amp draw...the 460 pumps draw like 18AMPS where as factory wiring is only good for 15AMPS max.Its commonly known as a hotwire loom it allows the factory loom to be plugged into the hotwire loom which then plugs into the pump.The earth wire cops a flogging on these factory clips with huge pumps. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1519631 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 29d Gender: Male Location: Central Queensland Posted 29/12/14 11:26 AM Share Posted 29/12/14 11:26 AM (edited) I too, had similar reservations as to the capability of the Walbro 255 l/h pump to keep the surge full, with prolonged periods of WOT. I am looking to push a bit more power than most, so, I ended up removing my PW surge tank and pumps and went for a KPM 1500hp in tank module. Edited 29/12/14 11:27 AM by HI PSI 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1519758 Share on other sites More sharing options...
f6 boss New Member 7 Member For: 13y 2m Posted 30/12/14 11:22 PM Share Posted 30/12/14 11:22 PM I am also going the intank route, as I am switching to e85 too.I called kpm for their stage 1 kit which includes walbro 460, fg modified pot, and fuel reg. it is suppose to be anti surge.It comes with an addition wiring to increase the amperage. I was quarantined by Dave at kpm as long as it was installed properly, it should max out 430 to 450 rwkw on e85 At .85 lambda, which is perfect for me as I only want to push standard gt3582 to low 400 range 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1520175 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 14d Gender: Male Posted 31/12/14 12:05 AM Share Posted 31/12/14 12:05 AM How much did it sting you for the single pump version? Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1520186 Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 12y 7m 27d Gender: Male Location: Sydney Posted 31/12/14 01:23 AM Share Posted 31/12/14 01:23 AM (edited) ^this is what I'm using.Just checked my records... Pump was $790.Comes with all necessary wiring, fuse, relay and the correct fuel pressure regulator. Edited 31/12/14 01:31 AM by Seaton 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1520201 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y Gender: Male Posted 01/01/15 09:38 AM Share Posted 01/01/15 09:38 AM The 460 pumps with "larger" pot is not by any means a surge solution.Make sure you remove the plastic fitting that is on the return line in cradle or drill it out as much as possible....it has a 4-5mm hole and slows cradle filling and return line operation is hampered with a larger pump.I run a 3/8 plastic line inside my cradle E85 friendly for the return with no fitting at all...hose sits snug in the hole just pushed in there. Link to comment https://www.fordxr6turbo.com/forum/topic/88742-intank-pump-upgrade/page/2/#findComment-1520601 Share on other sites More sharing options...
