Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 7d Gender: Male Location: Perth Posted 16/07/14 12:16 AM Share Posted 16/07/14 12:16 AM Am not. I'm now sitting down watching a fascinating show about airplane repossessions. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485663 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 3d Gender: Male Location: Perth Posted 16/07/14 12:37 AM Share Posted 16/07/14 12:37 AM Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485664 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m Gender: Male Posted 16/07/14 01:04 AM Share Posted 16/07/14 01:04 AM It will probably be fine (but I would check it with an a/f ratio meter to be sure). There is really no tuning going on with these PCMs. Just some adjustments to boost tables, getting injectors dialed in (if you changed injectors and only 3 numbers being juggled) and some raping of the ignition advance files.At moderate boost you can be out + or - 15% on the fuel and its all fine. Just make sure you run 98 fuel.There are too many who say, "oh yeh mate, you need a tune" but they have never done the job, just repeating words their tuner said so the tuner can rape them more. Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485670 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 3d Gender: Male Location: @ my laptop Posted 16/07/14 01:38 AM Share Posted 16/07/14 01:38 AM this is not correct 3 Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485675 Share on other sites More sharing options...
daveyboii Member 29 Member For: 10y 11m 2d Posted 16/07/14 01:51 AM Author Share Posted 16/07/14 01:51 AM sorry I should've mentioned it was a stock FG turbo so from what I've read that's GT3582 / GT35r being spoken as on a few forums, I just expected that the car would cough and fart under load since its not tuned with this turbo but seems like its just as powerful as it was on day 1, I am quite concerned about A/F ratio as I did mention it smells rich when you push it a bit but then garages are quoting me $600+ for a tune where it feels like it probably wont be a full tune kills my motivation to go out my way and take time off work and pay that much if its not something that requires a full day of R&D put into the vehicle Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485678 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m Gender: Male Posted 16/07/14 02:20 AM Share Posted 16/07/14 02:20 AM I got an FG with a GTX3582 also but 4" exhaust and nizpro intercooler and 1500cc injectorsA tune in its raw form is getting rid of boost cut, adjusting the boost table for desired boost and dialing in injectors. I am running a raw tune ATM. Its about 5 min work at I am running 12 :1 at 16 lb of boost no problemsThere is so much power there that there is no need to touch the timing tables and nor fueling tables. And its a PIA to play around with fueling because its all flash tuning as opposed to adjustments on the fly tuning.Now you can go further and start rescaling tables for higher boost and there are a few other adjustments to get rid of torque limits and the dash warning light but you would be surprised how little that needs to get done to run say 300-350 rwkw.You would be best to get something like an innovate wideband guage to see what your ratios are. It would be the best $200 you ever spend.Even Nizpro did a demo of how lean you can run engines at high load. Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485682 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 3d Gender: Male Location: @ my laptop Posted 16/07/14 02:26 AM Share Posted 16/07/14 02:26 AM Nizpro's demo had the timing altered to suit the lean condition 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485687 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 5d Gender: Male Location: Victoria Posted 16/07/14 02:32 AM Share Posted 16/07/14 02:32 AM What's the car worth to you? It's money being spent on peace of mind. How would your insurer see this if you made a claim and they noticed the modification? Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485688 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m Gender: Male Posted 16/07/14 02:37 AM Share Posted 16/07/14 02:37 AM On 16/07/2014 at 2:26 AM, ratter said: Nizpro's demo had the timing altered to suit the lean conditionI know Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485690 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 30d Gender: Male Location: Adelaide Posted 16/07/14 02:38 AM Share Posted 16/07/14 02:38 AM Bloody hell trana its all come out nowNo wonder u struggled with my riddles Stock timing table on 16psi .......... Right Link to comment https://www.fordxr6turbo.com/forum/topic/88732-is-a-tune-really-required-after-turbo-swapping/page/2/#findComment-1485691 Share on other sites More sharing options...
