Zf Installation
beauski
  • Moar Powar Babeh
  • Member For: 19y 3m 13d
Vitally important the convertor is fully seated before installing the engine/box. Measure the height of the flex plate above the block and ensure the distance between the front face of the convertor and the trans bell housing is greater than that. You need to line up the stator splines and then the pump drive lugs as the convertor goes in.
If you don't you risk damaging the convertor/box/pump.
