bjc Donating Members 2,823 Member For: 21y 8m 7d Gender: Male Location: Townsville Posted 16/07/14 02:31 PM Share Posted 16/07/14 02:31 PM (edited) So back to my other question...Is the Nizpro Overboost valve (I'll call it the NOB...) generally used for these spikes or no one gives a hoot about having 25+psi on gear changes? Edited 16/07/14 02:32 PM by bjc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88722-lowering-the-boost-to-safe-level-gtx3582r/page/4/#findComment-1485863 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 16d Gender: Male Location: Probably above atmospheric pressure Posted 16/07/14 02:35 PM Share Posted 16/07/14 02:35 PM Been giving my car hell for 230,000km, 320rwkw since 100,000km and no NOB in sighthahahaDoesn't mean it's not a good thing though. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88722-lowering-the-boost-to-safe-level-gtx3582r/page/4/#findComment-1485864 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 14d Gender: Male Location: Perth Posted 16/07/14 03:33 PM Share Posted 16/07/14 03:33 PM Its a safety device it catches that cold weather are mechanical malfunction overboost. Before I had mine on a cold night it sometimes would spike to 25psiMine is down on the passenger front next to the PCV catch can. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88722-lowering-the-boost-to-safe-level-gtx3582r/page/4/#findComment-1485869 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 7d Gender: Male Location: Townsville Posted 17/07/14 12:12 AM Share Posted 17/07/14 12:12 AM Mmmmm Black!We used GFB's Turbo Fuse back before the NOB was available but this device was attached in 2mins via the vacuum line to the bypass valve so when it activated you knew Haha.And from memory it would then keep the bypass valve open until vacuum was applied again...So the NOB is basically a wastegate then but fitted to the intake side of things? Why not just buy an adjustable wastegate, surely they are cheaper? Link to comment https://www.fordxr6turbo.com/forum/topic/88722-lowering-the-boost-to-safe-level-gtx3582r/page/4/#findComment-1485912 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 7d Gender: Male Location: Townsville Posted 27/07/14 07:04 AM Share Posted 27/07/14 07:04 AM OK, so I somehow managed to buy a NOB (from facebook of all things) from a WA bloke and got it for $200 delivered which is why I bought it...My question is, How do you set the desired boost level on this (was there a start setting and each turn meant roughly X amount of psi), should I use an air compressor for initial rough setting or is it a jump on the dyno and adjust on the fly thing?Were there instructions?Fitting it will be a PITA!!! Link to comment https://www.fordxr6turbo.com/forum/topic/88722-lowering-the-boost-to-safe-level-gtx3582r/page/4/#findComment-1487972 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 16d Gender: Male Location: Probably above atmospheric pressure Posted 27/07/14 09:49 AM Share Posted 27/07/14 09:49 AM I guess I'd get an air compressor plumbed on there somehow with no manual. Link to comment https://www.fordxr6turbo.com/forum/topic/88722-lowering-the-boost-to-safe-level-gtx3582r/page/4/#findComment-1488004 Share on other sites More sharing options...
