  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 7d
Stock fuel pumps/pots can suffer bad airation at low fuel levels and increased fuel temps even with a walbro intank the same happens
Having clean fuel filters is an easy maintenance step to keeping flow strong following that removing the swirl pot is easy and visually u can see if there is anything blocking the mesh sock attached to the pump
After that a fuel psi gauge will need to be fitted but as mentioned regs dont usually fail so down the line will be the issue as I said suss the intank pot/pump
What kind of kms is on the car and had the power been increased from stock ?
Having issues under 1/2 tank is fair common and its usually a clear indication the fuel system/filters are struggling for the flow required
  • Member For: 13y 2m 8d
ok guys got the t hooked up ...while revving through range pressure drops instead of increase I...idle pressure is about 4 bar with vac hooked up ..and increased a little with vac disconnected
boys I've for the pump out!
ok the steel rod is damaged ...now question ..everyone talks about a hose being damaged ..which is this..pulled the pump out ...this is all I have
post-50130-0-88559800-1405482986_thumb.j
Edited by horze
  • Member For: 17y 5m 13d
I'd be more worried about wooden rods with a stick motor
Seriously though props for putting in the hard yards and getting the pump out
lol about wooden stick
I hate iPhones always change my words lol
the work had to be done my friend
ok I have changed the fuel pump ( I have put a second hand sender in for testing purposes I gonna put a newy but can't get it till tomorrow
ok first things I've noticed
I now have 5 bar of pressure on idle with the vacuam hose plugged in
when I rev to about 3 grand and 4 grand it pretty much stays the same if not goes down a little
....funny thing is I called westpoint ford...they reckon a 6 non turbo and a 6 turbo fuel pump is the same
I need to order a pump ...what do U guys recommend ...should I just get another Delphi?
stock motor guys with just a f6 cooler
  • Spooling Member
  • Member For: 13y 5m 2d
  On 14/07/2014 at 10:56 PM, gaz097 said:
Did u get that backwards? The vacuum applied should take spring pressure away and therefore lower your pressure.
Ahh you are correct, got it the wrong way round.
well the guy at ford has no idea.... 6 na and 6 turbo is a diff fuel pump.... ive got the standard fuel pump in now.. and it feels like its running better.. so cant wait to put the proper one in..... seems like alot of people use a walbro as a aftermarket pump........ should I go a delphi or walbro... is the walbro mainly for modified engines?
  • Cruise Control
  • Member For: 19y 5m 2d
go the walbro mate tried and tested for years, make sure you get a genuine one though, beware ebay
