  • Bronze Donating Members
  • Member For: 11y 7m
I had a split fuel hose in my ba ute that would run low on power then limp mode. Mine was split about 15mm from the pump.
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 2d
  • Member For: 21y 10m 28d
fuel pressure should actually increase with boost pressure, not just hold even
Agreed.
Benny, would u test before fuel filter or at the regulator.. (vn's used to have a connection where the fuel rail is to hook up a pressure guage? ba's have anything like that?
I'd measure pressure as close to the rail as you can. I connect into the fuel line right before the rail on my GT. It will depend on how the gauge you have can be connected into the line.
If your issue gets worse with low fuel I'd be pulling the pump and swirl pot to check that as well. Not an easy job with a ute I know.
Benny.
Edited by Benny
  • Member For: 13y 4m 4d
Agreed.
Benny.
ok will try and hook up the reg tomorrow... benny any idea wat pressure it should be.... and regards to the fuel pump... ive just read up on it....... omfg wat a mission .. still havnt decided if im gonna change it from top or the bottom.... as from the bottom removing the tank is good to clean it
thanks for the help I will reply back tomorrow with it
  • Moar Powar Babeh
  • Member For: 19y 9m 10d
Id still be replacing those coils ......
So would I. Cracked = farked. Your meter can't tell you what's going on when the coils hot and under load.
I'll be amazed if it's a fuel pressure issue with a known suspect coil.
  • Member For: 13y 11m 12d
4 bar at idle. Should rise 1:1 with boost. Sounds like the problem I had. Car would not rev out with under half a tank, but had perfect pressure at idle. When the problem is happening does the car hunt back and forth?
thanks for the help boys
when you mean hunt what do you mean?
ralph I think I will change the coils like you said but still gotta be a problem with fuel being after half a tank issue gets real bad
  • Member For: 13y 5m 8d
Ok. So when adjusting my fuel pressure at idle, 4 bar with the vacuum line hooked up is too much?
Edited by willo88
