gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 1d Posted 14/07/14 10:47 PM Share Posted 14/07/14 10:47 PM (edited) Ok. So when adjusting my fuel pressure at idle, 4 bar with the vacuum line hooked up is too much?Potentially. Pull the vacuum hose of and stick your thumb over the hose and this is when u should have 4 bar.And hunt as in surge back and forth Edited 14/07/14 10:48 PM by gaz097 Link to comment Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 13y 1m 16d Gender: Male Location: Blue Mountains, NSW Posted 14/07/14 10:49 PM Share Posted 14/07/14 10:49 PM Mine was about 58-60psi (4 bar) with vac hose on and dropped about 10psi when vac hose off. FG, FPR2000, Plaz Dual Entry. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 1d Posted 14/07/14 10:56 PM Share Posted 14/07/14 10:56 PM Mine was about 58-60psi (4 bar) with vac hose on and dropped about 10psi when vac hose off. FG, FPR2000, Plaz Dual Entry.Did u get that backwards? The vacuum applied should take spring pressure away and therefore lower your pressure. Link to comment Share on other sites More sharing options...
horze Member 35 Member For: 12y 10m 23d Posted 15/07/14 02:42 AM Author Share Posted 15/07/14 02:42 AM boys where at you hooking up guage ... just had a look .. fuel line goes straight into reg and reg goes straight into fuel rail... then there is the vac line that goes into regseems like there is no spot to test after reg... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 30d Gender: Male Location: Perth Posted 15/07/14 02:49 AM Share Posted 15/07/14 02:49 AM You will need either fuel line adaptors , and disconnect the feed line from the hard line under the car and hook the gauge in there.Or you'll need to removed the clamps securing the feed hose the rail and install a barbed T piece in there. There's no provision for test Fuel Pressure as it's rarely an issue. Do you happen to have the torque app and a odb dongle?First point of call for fuel issues it would be easier to check the fuel trims before installing a gauge. Link to comment Share on other sites More sharing options...
willo88 Member 700 Member For: 12y 11m 28d Gender: Male Location: Newcastle Posted 15/07/14 02:59 AM Share Posted 15/07/14 02:59 AM Easiest way Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 30d Gender: Male Location: Perth Posted 15/07/14 03:00 AM Share Posted 15/07/14 03:00 AM I think that might leak mate. 1 Link to comment Share on other sites More sharing options...
willo88 Member 700 Member For: 12y 11m 28d Gender: Male Location: Newcastle Posted 15/07/14 03:14 AM Share Posted 15/07/14 03:14 AM There's me problem. My bad, only pic I have was during install Link to comment Share on other sites More sharing options...
horze Member 35 Member For: 12y 10m 23d Posted 15/07/14 05:42 AM Author Share Posted 15/07/14 05:42 AM ok well I've checked the fuel pressure after the fuel filter but only as a dead end ..it primed to 4 bar need to get a fitting to go into the click in fitting to make a t 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 22d Gender: Male Location: Adelaide Posted 15/07/14 06:21 AM Share Posted 15/07/14 06:21 AM Id just buy coils and move on ..... Link to comment Share on other sites More sharing options...
