pdizzle Member 47 Member For: 13y 11m 3d Gender: Male Location: wellington new zealand Posted 26/07/14 07:18 AM Author Share Posted 26/07/14 07:18 AM got side skirts and bumper off today.the skirts went too bad but still had bout a 30mm thick bead of sika flex!!! I peeled off the skirts ok but the thick strip of sealant is still on the ute! the bumper was such a *beep* to do mainly because I didnt have a socket to get the tow bar ball off same again though the pieces behind the rear wheel were glued to hell! I picked up a f6 tornado kit and looks like it will fit but may need some mounts for the bottom of the side skits as the kit sits alot lower Link to comment https://www.fordxr6turbo.com/forum/topic/88707-side-skirt-removal/page/2/#findComment-1487755 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 28d Gender: Male Location: near brisbane Posted 26/07/14 10:51 AM Share Posted 26/07/14 10:51 AM good on you for getting the parts off .sika flex is strong stuff .lol I got to rip out window frames and doors ,and hate the stuff .but it is the best sealant for water proofing .can you make the brackets out of aluminium ? Link to comment https://www.fordxr6turbo.com/forum/topic/88707-side-skirt-removal/page/2/#findComment-1487821 Share on other sites More sharing options...
pdizzle Member 47 Member For: 13y 11m 3d Gender: Male Location: wellington new zealand Posted 26/07/14 07:40 PM Author Share Posted 26/07/14 07:40 PM yea might try make up some z shaped supports probably gonna be tricky getting it to sit right though Link to comment https://www.fordxr6turbo.com/forum/topic/88707-side-skirt-removal/page/2/#findComment-1487890 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 28d Gender: Male Location: near brisbane Posted 26/07/14 10:46 PM Share Posted 26/07/14 10:46 PM but at least the clips at the out side should line up its only the inside ones that are wrong ? I would just use larger pop rivets to hold the brackets on the skirt part and some self taping gal screws on the sill ,and use rust proving inside of the holes and on the tread .I know that the sills are filled with foam for sound deadening and can course rust (had the problem with au xr6) ps 3 mm aluminium would be fine ,use insulation tape to stop electrolyses (rust )it can happen in salty areas Link to comment https://www.fordxr6turbo.com/forum/topic/88707-side-skirt-removal/page/2/#findComment-1487898 Share on other sites More sharing options...
madi1708 New Member 1 Member For: 6y 2m 14d Posted 12/04/19 01:44 AM Share Posted 12/04/19 01:44 AM hey guys anyone know where you can get replacement clips from to hold the side skirt on I have a 2010 fg sedan Link to comment https://www.fordxr6turbo.com/forum/topic/88707-side-skirt-removal/page/2/#findComment-1681430 Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 10m 11d Posted 12/04/19 01:53 AM Share Posted 12/04/19 01:53 AM like this? https://www.ebay.com.au/itm/20-x-Ford-Falcon-Side-Skirt-Sill-Clips-/262141115181 Link to comment https://www.fordxr6turbo.com/forum/topic/88707-side-skirt-removal/page/2/#findComment-1681431 Share on other sites More sharing options...
