spook Donating Members 180 Member For: 17y 2m 29d Gender: Male Posted 16/09/14 08:29 AM Share Posted 16/09/14 08:29 AM Just fitted these to my BF. Should have done it sooner as car now feels as if it's lost weight. We'll worth it 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1499624 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 20d Gender: Male Location: Perth Posted 16/09/14 08:38 AM Share Posted 16/09/14 08:38 AM I posted this elsewhere, but figured I should add my thoughts to this thread also.I played with the settings on my Shockworks the other day. First chance I've had to really give them a good test since having them fitted. I had to take the rear wheel off first to see where the adjuster for the rear dampener was, but now I know where it is it's easy enough to reach from under the car.Definitely a night and day improvement in handling! The floaty boat characteristics are gone and the car feels much more composed. Grip feels to have increased and to be much more progressive and predictable.There's also a much more noticeable difference between fully hard and fully soft than I found with the Teins in my old car. Fully soft with the Shockworks is great for just cruising around on, still has great handling but maintains almost OEM type levels of comfort. Fully hard is ridiculous! It's not painful, but it's uncomfortable. The car transmits every bump and bounces around heaps if there's bumps through a corner. Brett's recommendation of 3 on the front and 4 on the back (0 being the softest and 10 being the hardest) seems like a great compromise for spirited street driving. The suspension soaks up the bumps without unsettling the car and allows a heap of grip. The car also sits flats though the turns and doesn't jump around when you're on the limits of grip.I'm pretty happy so far.I should add too that a mate of mine had a drive this arvo. He'd driven it stock before and at the time thought it didn't inspire confidence through the twisties at all. He jumped in it today and his comment was "I'm actually really enjoying driving your car now, this is much better!" Just as a comparison, he's got Teins in his Monaro, so he's used to somewhat similar cars handling.I find them more enjoyable than my Teins were, in that they feel like they work with the chassis better...unless you have them on full hard, then they're not pleasant on the road haha. I've only done a quick test on fully soft and it was comfortable. Might be stretching a little bit to compare the same exact setting on my Teins but I can tell you that even driving around on 3 front and 4 rear isn't uncomfortable for a daily and is great if you feel the need to throw it through some corners. Body roll is no longer an issue. These things keep surprising me and get better and better the more I drive with them. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1499627 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 1m 22d Gender: Male Location: Gold Coast Posted 16/09/14 09:25 AM Share Posted 16/09/14 09:25 AM ^^^ chubby, engage 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1499645 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 20d Gender: Male Location: Perth Posted 16/09/14 09:30 AM Share Posted 16/09/14 09:30 AM Do it Bomber! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1499647 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 1m 22d Gender: Male Location: Gold Coast Posted 16/09/14 09:33 AM Share Posted 16/09/14 09:33 AM Sigh, need some more coin. On the plus side, should pick up some coin for my SSL's and Monroes. Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1499649 Share on other sites More sharing options...
spook Donating Members 180 Member For: 17y 2m 29d Gender: Male Posted 16/09/14 10:39 AM Share Posted 16/09/14 10:39 AM I'm still running on the softest setting and cannot get over how flat the car sits around corners. I'll have a play with the firmness over the next few days. Can just squeeze my hand through the wheels to adjust the rears which helps for quick adjustments. If your considering these coil overs you will not regret the decision. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1499662 Share on other sites More sharing options...
raised by monkeys Member 90 Member For: 10y 9m 22d Gender: Male Location: Whyalla, SA Posted 27/09/14 11:48 AM Share Posted 27/09/14 11:48 AM I contacted SHOCKWORKS and I have to wait about 3 weeks. Wanting front coil overs and OEM spring and adj rear dampers. Just a quick Q RE: ride lower height. Did you guys order OEM replacement? or did you ask for a lower stance? Should I ask for slightly lower spring or can I achieve a lower stance with reducing the coilover/damper thrust? Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1502223 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 8d Gender: Male Location: Frankston, 3199 Posted 27/09/14 01:43 PM Share Posted 27/09/14 01:43 PM The coilovers adjust the height without effecting the springs - basically the shaft is lengthened/shortened while keeping the springs at the same length/compression.The OEM replacements they offer are different to the coilovers - non adjustableDo you mean you want coilovers in the front and OEM replacements in the rear instead of coilovers all round? (front would be height adjustable, rear wouldn't) I'm not sure if they offer shorter springs/adjustable dampers in the OEM range Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1502242 Share on other sites More sharing options...
raised by monkeys Member 90 Member For: 10y 9m 22d Gender: Male Location: Whyalla, SA Posted 27/09/14 02:03 PM Share Posted 27/09/14 02:03 PM Sorry, I meant replacement OEM springs with coilovers in the front, and adjustable dampers in the rear using the stock leafs.So im right in thinking that I can adjust the ride height through the coilover alone in the front? does it matter what size spring I use?. Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1502246 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 8d Gender: Male Location: Frankston, 3199 Posted 27/09/14 02:24 PM Share Posted 27/09/14 02:24 PM The coilovers come with the matched springs (they "coilover" the shocks/dampers in a single unit) Link to comment https://www.fordxr6turbo.com/forum/topic/88673-shockworks-coilovers-installation-impressions-pics/page/7/#findComment-1502249 Share on other sites More sharing options...
