  • WOT?
  • Moderating Team
  • Member For: 12y 4m 8d
There was a great vid I saw somewhere showing how too stiff/too loose effects the grip/contact patches on the road.
I think they used a speed hump or corrugation for one example - too hard or too soft the contact was a lot less than one set up just right
Same with body roll - needed a little to weight the tyres
(I think that was the gist of it - vid was probably from here somewhere)
Amazing the difference the surface makes too.
3 notches from soft was perfect for me on decent roads - far too firm over some roads I was on over the weekend - softened it a notch and was in heaven again. Was amazed at the difference even 1 click made - can be a very fine line
Edited by Rab
  • Member For: 12y 4m 7d
Do you need to jack the car up to adjust em? Or you just reach in with the tool and twist the thing? Sorry coilover noob, curious
  • WOT?
  • Moderating Team
Aren't adjusting the height (what you need to tool for) - am happy with where it is and would need a alignment done after changing it.
What I am adjusting is the firmness in the shocks.
Is just a knob/dial on top of the shock that twists clockwise/anticlockwise for firmer/softer.
Pop bonnet - turn dial - front done.
Haven't adjusted the rear yet - but would be the same - reach under car, turn dial - done
Edited by Rab
  • WOT?
  • Moderating Team
Am still blown away by the difference it's made.
If I had to do my time over or was buying another FG I'd be doing this and upgrading the stock pads on the way home from the dealer - definite no-brainer.
Those two items are how the cars should be leaving the factory stock.
Edited by Rab
  • WOT?
  • Moderating Team
Don't think they have an account here - they have a fairly long topic on the sponsor section of AFF
  • Member For: 17y 10m 14d
I posted on AFF asking about optimal settings for track use and didn't get a reply from Shockworks. Most of their testing will have been done on the road. I did some testing the other week during at a track event, and did notice an increase in understeer as I firmed up the front end. I ended up driving with 8/10 front and 7/10 rear, which was effective with the Sport Maxx at around 34psi hot. Next event (in November) will be done with R888s, and I'm hoping to go to 10/10 front and a notch less at the rear.
  • Member For: 19y 1m 6d
every track would be different and even different on different days, not to even start considering tyre type and pressure etc, this is why race cars spend days qualifying to get the car set up correct.
