Fuel Rails Which One? Why?
  • Member For: 11y 9m 2d
Also Throttle body Relocation kit, if that makes a difference ^
Edit: Process West ofcourse
Edited by Peppy_t92
Process West site gives you a pretty good idea... My standard rail was fine with twin DW300's and over 400rwkw... But now I have twin walbro 460's and it's just way too much fuel flow for my reg and rail to keep the pressure down
  • Bronze Donating Members
  • Member For: 13y 5m 15d
Yeah I have had a good look at the process west setup and pretty much copied it. I can get my base pressure below 2 bar running twin 044's into the standard rail. Seems to be up to the task so far.
  • RNS10S
  • Member For: 18y 4m 20d
Pretty sure you can leave your rail and just add a FPR
http://www.processwest.com.au/images/articles/subsurge34.jpg
I looked into that, I wasn't sure if the adapter that goes onto the rail would provide enough flow? I'm still not sure if the return line back to the tank will flow enough
  • Member For: 18y 7m 11d
My best advice that I can give you... Is don't be a scrooge, as you will only have to fork out more money, later down the line. Buy right, buy once...
Edited by HI PSI
  • Like 2
Haha well on that note I actually bought the turbosmart adapter which just relocates the reg and had a bit of an issue here. Even with modifiying the intank pump I couldn't get base pressure below 3 bar. After I drilled the inner hole bigger it went down. Looking back should have bought a dual entry rail etc lol oh well live and learn.
