Help! Ba Xr6T With Serious Issue
Maccarossi
  • Member For: 15y 9m 4d
Hi All,
Hopefully someone here can help me having a serious problem with my BA MKII XR6T right now. I start the engine and it idles well enough but as soon as I put it into gear the engine light comes on and the power is cut to the engine and I can only start it again by turning the car completely off and starting it again but it still does the same thing.
It's a Sunday and even if a mechanic were open I couldn't drive the car there, can anyone offer up some advice as to what I could try looking at? I'm handy enough working on cars provided I know what to look for, any help would be greatly appreciated, thanks!
Try disconnecting the battery for a bit and then reconnect and try again?
Yeah this is what I'm currently doing it's been off for about 15 mins now so was looking for other things too if this doesn't work, have also cleaned the throttle body so far as well :)
  • Im the one and only
  • Member For: 20y 3d
Look. others might elaborate on the idea of a TPS sensor causing it to throw a engine light on and stall. My old BA used to throw a light and stall when driving. It was a dodgy TPS sensor that caused it.
Bit of an update, disconnected the battery again, pumped the break and tried to use headlights etc. to discharge completely and then reconnected the battery after about an hour and it's made the problem worse :S
Now when I start the car it idles at about 2500RPM (sounds way too high) for about 5 seconds then the engine cuts out.
Sounds like a big vac leak.
Cheers! trying to find it now, nothing obvious from what I can see, I have a plazmaman intercooler and the large hose going into the intake manifold seems fine, I can hear a faint hissing sound though for those few seconds when it idles so I think you might be onto something there
Hmmm couldn't find any vac leaks but it;s starting and idling in P or N now no worries, but once it goes into gear that's when things start to get really interesting! Just made a quick video of what is happening.
  • Like 2
