  • Member For: 11y 6m 16d
Could be alot of things, plugs, coils, fuel filter, pump, actuator, boost cut even. Can you make a vid off the instrument cluster when it happens. May or may not help.
  • New Member
  • Member For: 12y 8m
I had the same problem with my 04BA. When boosted to exactly 3000RPM, it hit a flat spot. I changed the leads and spark plug and it fixed the problem.
The spark plugs and leads looked fine, resistance of all leads were fine. I am sure one of the leads internally was shorting when a high demand was required.
Hope this helps
