norrs Donating Members 448 Member For: 17y 11m 16d Gender: Male Location: Darwin Posted 03/07/14 11:57 PM Share Posted 03/07/14 11:57 PM Ok its been a while since I posted as I sold the old car. Anyway, I now have an FG F6 and I'm back.It has a Process West Surge tank (old style single pump) mounted under the passenger side. I swear that the whining is louder than it was a month ago. The whining is louder than the radio. I tried to record it today for you guys to listen too. I just need to know if this is normal or is it about to sh*t it's self.I ran the car the other day and jumped underneath it. The mounting seems secure, I'm certain it is coming from the pump.Hopefully the MP3 of the recording will be linked below for you guys to listen to. This was taken in the car park idling. and then at the end I turn the car off. As you can hear it the frequency of the whine changes while idling.Fuel Pump.mp3 Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 8d Gender: Male Location: Adelaide Posted 04/07/14 12:44 AM Share Posted 04/07/14 12:44 AM How much fuel do u have in the car when u recorded this ?How long was it running when u recorded this ?044's are noisy for a few reasons and still ok But they can also change tone when they are on the way out And that seemed to be normal to fair noise depending where u were when recording Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482836 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 28d Gender: Male Posted 04/07/14 01:31 AM Share Posted 04/07/14 01:31 AM My twin 044's WERE quiet! Untill we fitted a Teflon return line and replaced a hose from surge to pump! Now the cunt5 noisy as :/ Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482853 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 11m 16d Gender: Male Location: Darwin Posted 04/07/14 02:22 AM Author Share Posted 04/07/14 02:22 AM Hey Jet I had just finished driving for 30 minutes and pulled up to record it. However, the noise is the same regardless of whether I have just started it in the morning or if I have driven for an hour.My fuel was 75% but remember I'm talking about the pump on my surge tank not the one in the original tank.This was recorded in the drivers seat with the windows wound up. You can't hear yourself think outside of the car. I have to yell at the girl at drive throughs. I might do another recording out of the car.Is there a way to test if it is on the way out, is it fluctuating or dropping furl pressure? Is this one of the things I can log on my obd Scanner app?The changing in the pitch of the whining while at idle is my main concern, surely that isn't normal. Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482866 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 8d Gender: Male Location: Adelaide Posted 04/07/14 02:52 AM Share Posted 04/07/14 02:52 AM Because its a return style system it heats the fuel and the density of the fuel effects flow/load on the pump so that's why an o44 can be noisyer at low fuel levels and after driving its well heated up that's why I was asking You can not tell fuel psi on any monitoring system u need to manually connect a gauge I recomend this in your case Best part is genuine o44's can be had for sub $200 Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482880 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 11m 16d Gender: Male Location: Darwin Posted 04/07/14 03:11 AM Author Share Posted 04/07/14 03:11 AM thanks jeturbo. I learned something today 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482884 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 16d Gender: Male Location: Perth Posted 04/07/14 03:19 AM Share Posted 04/07/14 03:19 AM I don't find my 044 that norrs-y(boom tish) 3 Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482885 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 8d Gender: Male Location: Adelaide Posted 04/07/14 03:29 AM Share Posted 04/07/14 03:29 AM We just did a plaz undercar surgetank install and its real quiet infact bloody amazing A large part of undercar surge noise is the mounting from the o44 to the tank then the tank to chassis rail all plays a vital part in noise Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482886 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 11m 16d Gender: Male Location: Darwin Posted 04/07/14 06:37 AM Author Share Posted 04/07/14 06:37 AM Mine is like the attached photo. Nice rubber mounts to body and rubber around the pump. Anyway, I'll take it into you mechanic to test the pressure. Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1482922 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 3m 8d Gender: Male Posted 04/07/14 04:20 PM Share Posted 04/07/14 04:20 PM 044's are just a sh*t pump that will embaras u with that typical erratic noise you posted. I never got to the bottom of why (it will do it on a brand new pump) but one theory that I suspect is that maybe the screw on thing on the front of a new pump that we all throw in the bin may help keep it quiet but I never tried using it with it on. Keeping fuel cool helps but that surge tank setup definately heats the fuel up heaps and makes the problem heaps worse. It sounds like you have not run this set up on a hot summers day as it will go 10x troppo. Link to comment https://www.fordxr6turbo.com/forum/topic/88647-pw-surge-tank-fuel-pump-noise/#findComment-1483083 Share on other sites More sharing options...
