Fg Turbo Accelerating Issue
FORCEDG6E
  • Member For: 13y 3m 26d
Got a problem with my fg turbo zf six speed. While driving at a constant speed the vehicle sometimes incresease speed slightly and drops back like its hunting. Also does it with cruise engaged. Thinking possibly tps or something? Thanks
  • Member For: 15y 11m 15d
Have you checked coolant level and colour? If the heat exchanger on the side of the zf splits it can cause tranny fluid to mix with coolant and it gives the car a constant hunting feeling
  • Too heavy needs boost
  • Member For: 11y 3m 17d
mine does it to sometimes after some wot. next time when its happening just accelerate a little bit and see if it continues to accelerate for a second after. mine does it on cruise and in normal driving every now and then to.
will be interested to see what people say about this issue.
  • Member For: 12y 5m 27d
No this is not normal cold or hot, my car does not do this.
You need to determine
1. Is it switching between 2 gears causing the change in speed
2. is the throttle plate moving which is causing the change in speed
Edited by Z2TT
