FORCEDG6E Member 145 Member For: 13y 6m 22d Gender: Male Location: adelaide Posted 02/07/14 10:13 AM Share Posted 02/07/14 10:13 AM Got a problem with my fg turbo zf six speed. While driving at a constant speed the vehicle sometimes incresease speed slightly and drops back like its hunting. Also does it with cruise engaged. Thinking possibly tps or something? Thanks Link to comment Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 2m 12d Gender: Male Location: CQ Posted 02/07/14 10:36 AM Share Posted 02/07/14 10:36 AM Have you checked coolant level and colour? If the heat exchanger on the side of the zf splits it can cause tranny fluid to mix with coolant and it gives the car a constant hunting feeling Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 22d Gender: Male Location: adelaide Posted 02/07/14 10:47 AM Author Share Posted 02/07/14 10:47 AM Yeah mate coolants all good its not all the time only does.it every coulple weeks for about 1 minute Link to comment Share on other sites More sharing options...
Knackers Member 102 Member For: 14y 19d Posted 03/07/14 11:11 AM Share Posted 03/07/14 11:11 AM Does it do it when the car is up to operating temperature or generally within the first 10minutes of driving from a cold start?If it's after a cold start - it's normal. Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 22d Gender: Male Location: adelaide Posted 05/07/14 11:26 PM Author Share Posted 05/07/14 11:26 PM Nah does it after driving for a while I drove for two hours once and it did it for about 30seconds Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 14d Gender: Male Location: Adelaide Posted 06/07/14 12:05 AM Share Posted 06/07/14 12:05 AM mine does it to sometimes after some wot. next time when its happening just accelerate a little bit and see if it continues to accelerate for a second after. mine does it on cruise and in normal driving every now and then to.will be interested to see what people say about this issue. Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 22d Gender: Male Location: adelaide Posted 06/07/14 12:45 AM Author Share Posted 06/07/14 12:45 AM Yeah mine does it after some wot aswell. When its doing it I give it some sh*t it stops for a sec then does it. Link to comment Share on other sites More sharing options...
Z2TT Member 714 Member For: 12y 8m 24d Posted 06/07/14 10:02 AM Share Posted 06/07/14 10:02 AM (edited) No this is not normal cold or hot, my car does not do this.You need to determine1. Is it switching between 2 gears causing the change in speed2. is the throttle plate moving which is causing the change in speed Edited 06/07/14 10:05 AM by Z2TT Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 14d Gender: Male Location: Adelaide Posted 06/07/14 10:33 AM Share Posted 06/07/14 10:33 AM throttle plate. ? its not doing it between gears. Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 22d Gender: Male Location: adelaide Posted 06/07/14 11:06 AM Author Share Posted 06/07/14 11:06 AM No its not switching between gears.. not sure everytime I go to put scope on car it dosent fault 1 Link to comment Share on other sites More sharing options...
