  • Member For: 19y 2m 18d
Hardy's at Eagle Farm have been replacing CV's with Uni's but Hardy's at Darra have got a trick CV setup on the go.
I have heard the Darra ones are quite a bit less prone to vibrations.
Someone with more knowledge might be able to explain why a CV might be better - I thought it had something to do with pinion angles being a bit too big in these things for a uni to work as intended (both strength and NVH) however I was pretty blind last time someone was talking to me about this so it could all be fabrication.
Edited by old_mate
  • Like 2
  • Member For: 13y 8m 26d
Im chasing a shaft in townsville , my mates chasing one up for me cause hardie quoted me $2500, I was thinking that's a bit to much I was thinking they around the 1200-1700 fitted but ill just have to see , cars only got 300rwkw but its running nizpro stage 2 zf with bittet intermeidate and 275mt ets going for a 11.9 or lower with stock converter , its all just in prep for the new turbo and possible rebuild with all the good stuff , still unsure on what turbo to run
  • Member For: 12y 5m 26d
vevapower has run a 9 second pass on a retubed tailshaft from propeller shaft services in Bankstown, only around $500. I dont think many people on here are even close to running 9 second passes.
I know half a dozen people that have had their tailshafts done there, not one has failed, $1500 on a tailshaft is a waste of money IMHO
I will be getting my tailshaft retubed at propeller soon
Edited by sct911
  • Member For: 12y
got the same in mine ..... no need for 1000hp shaft if u are never gonna have 1000hp
  • Member For: 11y 3m 3d
I got the shaft made and its great .for $750 ,of farrows at nambour
great work and cheap ,we ended up fitting two washers under the centre bearing and it got rid off the tail shaft vibration . its all good now
  • www.australianflag.org.au
  • Member For: 19y 9m 15d
wow so many options. Hardy Spicer at Darra quoted 2k for a full new build with the upgraded rear CV and bigger center bearing; 480 ex GST to retube my shaft.
10SECN so your shaft is retubed but stock center bearing and rear CV? I am only looking to end up around 600rwhp and will bolt on some sticky tyres once or twice to run that 10 second / 130mph pass - don't want to overkill as you said before but then again don't want to do it twice because it broke
