Miss Fire Under Load And Revving Down
Brad 'Rangy' Rangott
  • Member For: 10y 7m 15d
yeah 0.8 for when I put the capa chip in but I haven't sorted this problem out, I pulled the front bar out check all the intercooler lines nothing I notice this sensor had to lines going into it just near the throttle body it hanging there under the intake plenum it has a vacume line from the plenum or throttle and a metal line that wont lock in properly that I think comes from the fuel tank im not sure does anyone know what that is?im guessing map sensor but I have no clue that could be a problem?
or do you guys still think genuine coil packs I don't want to spend more money on coil packs and its not it, im only thinking that because I pulled non genuine ones out (vdo) and was misfiring till now and then I put a different non genuine coil pack (osa) still exactly the same .
  • 2 weeks later...
I took the car to ford dealer and they found a error code saying cam shaft sensor is out it was advanced 9* when it wasn't and they reckon it was the sensors .1300 later car was good and next day guess what missfiring faaaaarrk ill post when I find out what is going on with this big mystery
Sent from my iPhone using Tapatalk
  • 4 weeks later...
alrighty finally solve it was fouled cam sensors from previous owner not changing oil enough the timing was out as well but reckons it didn't jump a tooth also another problem was sh*t fuel from batemans bay shell vpower 98 this is the second time I had problem with there fuel my Nissan gtr had problems from there fuel when I last went on holidays up there, ive drained the fuel and put my home town fuel back in it with some octone booster and cleaner no more misfire , So in final point F@#K!!!! shell in batemans bay do not fuel up your car there my guess its not 98 octane there or crappy fuel.
  • Like 2
