SecaBoy Donating Members 203 Member For: 16y 1m 6d Posted 18/06/14 01:06 PM Share Posted 18/06/14 01:06 PM HeySo, I've got a few issues with my FG XR6T and just wanted to see if anyone can give me some ideas of what could be causing my issues.I'll obviously be taking it to a professional to get diagnosed/fixed properly, but with a wedding coming up in a couple of months, I need to know if its something serious or could be delayed a bit. :(The car has an F6 turbo, high flowed injectors, intake/intercooler upgrade, valve springs and a tune (stock exhaust). All this work happened over a year ago and hasn't missed a beat since.1) When you start the car, the exhaust smells of unburnt fuel. Its WAY worse on a cold start.2) After you start the car and let it warm up and drive away, for the first few kms, it'll surge slightly if you hold the accelerator steady. ie, if you are just cruising at 60km/h or 70km/h for example.3) Idle is fine, but sometimes when you come to a stop, it'll drop below 500rpm for a split second and then idle normally (its an auto)4) I have a lead foot and normally see about 12-13l/100km. Since these problems, I'm seeing about 14.5-16l/100km with the same sort of driving and same route I take to work and back every day.5) At night, if I go WOT with a car behind me, it looks like the guy behind me is driving through fog.6) Don't know if its done on power, or if I'm just used to the power increase, so I can't really comment on that.Any sort of help or ideas you can give would be appreciated. Thank you. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 10m 4d Gender: Male Location: Central Coast Posted 18/06/14 01:32 PM Share Posted 18/06/14 01:32 PM Tuna mate take it back straight away He'll be able to help If it was perfectly after the tune and then this happened I'd be inclined to look at an o2 sensor But speak to your tuna asap Link to comment Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 1m 6d Posted 18/06/14 02:11 PM Author Share Posted 18/06/14 02:11 PM Fair enough. I'll try to figure out a way to get it to them. Such a massive pain in the ass. Critical time at work and I need it to get to work everyday. 1 Link to comment Share on other sites More sharing options...
Z2TT Member 714 Member For: 12y 9m 10d Posted 18/06/14 02:41 PM Share Posted 18/06/14 02:41 PM (edited) There can be various things that can cause the problems you mention, but likely things can be :1. Faulty Injector or stuck injector3. Could be problem with throttle motor/actuator.4. Sounds normal to use a lot of fuel when driving hard, but using more fuel than normally may be related to issue 1.5. Over-fuelling and/or faulty injectors, tune not matched to injectors, not tuned correctly. Edited 18/06/14 02:42 PM by Z2TT Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 11m 6d Gender: Male Location: Liverpool Posted 18/06/14 10:32 PM Share Posted 18/06/14 10:32 PM High flowed injectors? As in Drilled? Link to comment Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 1m 6d Posted 18/06/14 10:44 PM Author Share Posted 18/06/14 10:44 PM not sure mate. I assume high flowed means drilled. elite automotive did all the work. Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 11m 6d Gender: Male Location: Liverpool Posted 18/06/14 10:57 PM Share Posted 18/06/14 10:57 PM Like z2tt said it could be all of those things... Drilled injectors are extremely hard to tune, even impossible to get them to idle/drive like a quality injector.. Best bet would be to speak to your tuner.. Link to comment Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 1m 6d Posted 18/06/14 11:04 PM Author Share Posted 18/06/14 11:04 PM yeah, but what I dont understand is that its been fine for well over a year now. the mods/tune isnt a new thing. Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 11m 6d Gender: Male Location: Liverpool Posted 18/06/14 11:09 PM Share Posted 18/06/14 11:09 PM Right, well that makes it a little more strange.. Could be a dirty or failed injector, I havn't heard if too many failing 02 sensors, but I could be wrong Link to comment Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 1m 6d Posted 18/06/14 11:38 PM Author Share Posted 18/06/14 11:38 PM Booked in on Wednesday next week. So fingers crossed, its nothing major. Link to comment Share on other sites More sharing options...
