  • Bronze Donating Members
  • Member For: 12y 2m 21d
^^ The Nizpro 'zorst doesn't have flanges -- it uses V-Bands and there is a lot of adjustability in them but doing it by myself is a bit hard.
Even though it was on a hoist, I ain't clever enough :)
  • Carnage on the Garage Floor
  • Member For: 15y 1m 17d
Are they the Koya Bathurst? 18" staggered?
Spot on Bomber
Mine and Wombats car are still the only 2 that I know of with them.... must be some more in the country - you'd think :)
  • 3 weeks later...
Quick report on the ULX110 engine oil
After a couple of weeks and no difference in my driving style, I have noticed a couple of different things between this and the Nulon oil.
First up, in the last few days, I've noticed that the engine runs a bit quieter (once you get the injector tick out of your head) but the big one is on cold start.
With the Nulon -- because I have my oil gauge 'low' warning light set to 15psi -- I noticed that even with brand new oil that it takes a bit for the warning light to turn off in the morning and the gauge to stablize at about 60 or 62 (ish)psi (remember - cold start) whereas with the ULX110, it immediately hits 65psi and I mean -- as soon as the car fires. :)
I've only done about a thousand k's with it so far so I'll keep an eye on it but I really do reckon that this stuff is worth the extra money.
As you all would remember, I shattered the inner CV on the rhs Half Shaft a while back and had to replace it -- too much torque = sweeeet -- so last week we swapped out the left one with another Repco shaft ( the cv's a quite a bit larger on these than the stock jobbies) just for that "piece of mind" thing and through a comedy of errors, this little problem then surfaced.
Farken lololol. Ya reckon that might be a collapsed bearing???? hehe
(Warning - Bloosted swears in the video)
My advice, try not to drive the car if it gets this bad :( I'm not sure if the wheel and hub can 'actually' separate but for safety, don't take the chance please.
I'm not going to get a new bearing pressed in or even get the hub with bearing installed and have that pressed in because I've read here and on the other forum that if you swap a bearing (hub) once, your likely to have to do it again and again and again so we swapped out the complete assy with one we got from Gawler wreckers on Saturday morning as I wanted to go on the High Rollers cruise that night but this one is sooooooo friggen noisy haha. Boy do I need noisy......and when I say noisy, I mean NOISY.
A complete assy off a low km FG will see it all sorted this week ;)
Again, I have to remind myself that Roxy may be driven every day and be relied on, but with this sort of power, sh*t gunna happen...............................
  • Like 2
  • Member For: 17y 7m 7d
My car recently did the rear left bearing as well, I bought a bearing off eBay and pressed it in myself $60 all up so hopefully it lasts.
I hadn't heard of the problem your talking about, but mine has only been in for about 4000k's
Also FYI... The hub can't come off as long as the nut on the half shaft stays on
But it could definitely seize and lock up, causing all sorts of horrible damage
Best not to drive it as you mentioned
Bloody cars always something to do on them
  • Member For: 12y 1m 3d
Im confused? I got my rear right hub bearing replaced by Ford...you saying it will continually fail?
Or are you saying if they did it properly (I.e. whole hub + bearing assembly) that that should be ok?
That was a funny video :spoton:
Yeah that's what I thought Wilko but didn't wanna commit to saying what you said only coz I wasn't positive.
Mainly from the other forum Pete
In a cupla threads, people speak of having to change them (bearings only) again and again.........My guess is that there is probably something else going on, and the 10 to 20 thou k mark was mentioned when change-outs were required.
There was one guy that said -- IF I recall correctly -- his has lasted heaps long time <-- my words not his, but even the guy at my local Ford dealer suggested to replace the entire Hub (which comes with the bearings installed) as he knows of a couple of cars recently that have come back into their service center under warrenty when ONLY the bearings were replaced.
Bottom line for me is that if I/we can find an entire, all genuine, low km one off an FG that HASN'T lived out in the weather all exposed and sh*t, then I would be better off going that way rather than run the risk of someone farking up when pressing bearings in :)
Ford Mt Barker SA gave me these prices
Bearing Kit $148.50
Hub w/ Kit installed $289.60
I'm not sure how it can come pre installed on to the hub... As the hub and bearing get pressed in from opposite sides ?
Unless I'm a spaz and didn't do it properly haha
