Fg Exhaust On Bf
CHLAXN
  • 5 months later...
  • Member For: 17y 3m 3d
How did the Fg 4" exhaust end up? Did you need a custom dump pipe In the end?
Love the single tip at the back. I would like to do something similar.
  • Member For: 16y 8m 2d
Works fine mate ended up using a FG exhaust manifold and full FG xforce 4" turbo back system fits fine mate.
FG exhaust manifold, precision 6466 FG 4" xforce dump
  • Like 4
How hard is it to fit the FG exhaust manifold? how does it go with changing the position of the turbo when it comes to water/oil pipes?
Piece of piss to fit mate if you have an idea how to use a spanner. I have custom oil feed and return lines, Precision turbo does not run water lines. Not sure if you could retro fit FG oil/water feed and return lines onto a b series but not hard to make your own lines anyway if needed.
  • Sandtrap Motorsport
  • Member For: 16y 2m
I modified a B series oil drain to fit, picking up a FG drain on Friday (hopefully).
If you go FG intake, get the FG engine coolant hard lines.
The harness lay is tight but possible.
