BISHY1 New Member 11 Member For: 12y 4m 18d Posted 13/06/14 08:54 PM Share Posted 13/06/14 08:54 PM Is there a good and bad upgrade caliper for ba bf turbos? Was there two versions of the pbr upgrade? I'm sure I read there were two, one has a little cut out bit to tell.. Or is this not true? Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/ Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 4m 12d Posted 14/06/14 12:00 AM Share Posted 14/06/14 12:00 AM All the factory non-Brembo calipers for the XR6 Turbo's were PBR (which is now owned by Bosch) The 'good-one' is the two-pot, light-weight PBR calipers supplied for the front of the Corvette. (PBR also supplies a very high end six-pot, six-pad caliper for the uber Corvette models) These calipers are easy to spot. They have a smooth forged surface (as opposed to a sand casting surface) and they are:- Painted Black when supplied as part of the XR6 Factory Premium Brake Upgrade. The decal says Ford. - Painted Blue when supplied on a BA FVP standard brake. The decal says FPV... I think- Painted Red (or Yellow? and...) when supplied direct by PBR as part of an aftermarket upgrade kit. The decal says PBR.The rear caliper stays the same as in the standard brake set. Except in the PBR aftermarket kits where the rear (standard calipers) are also colour coded red (and yellow and..) 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478335 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 6m 7d Gender: Male Location: Brisbane Posted 14/06/14 12:16 AM Share Posted 14/06/14 12:16 AM http://www.herrodmotorsport.com.au/herrodperformanceproducts/brakes/bafalcon/tabid/169/default.aspx Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478338 Share on other sites More sharing options...
BISHY1 New Member 11 Member For: 12y 4m 18d Posted 14/06/14 01:18 AM Author Share Posted 14/06/14 01:18 AM Are cheers. I thoughts they were similar. But I see some have a smother are that's is cut near the ends as aposed to these. Same sane? These correct ? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478346 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 6m 7d Gender: Male Location: Brisbane Posted 14/06/14 02:46 AM Share Posted 14/06/14 02:46 AM that's them Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478369 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m Gender: Male Location: Perth Posted 14/06/14 04:01 AM Share Posted 14/06/14 04:01 AM Yep Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478390 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m Gender: Male Location: Perth Posted 14/06/14 04:02 AM Share Posted 14/06/14 04:02 AM Yep..... Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478392 Share on other sites More sharing options...
BISHY1 New Member 11 Member For: 12y 4m 18d Posted 14/06/14 06:35 AM Author Share Posted 14/06/14 06:35 AM Value? Link to comment https://www.fordxr6turbo.com/forum/topic/88507-ba-pbr-calipers-good-and-bad-ones/#findComment-1478431 Share on other sites More sharing options...
