  • All stock bar the k&n panel filter
  • Member For: 13y 2m 23d
True, I had the Teins in my turbo, they could have been more comfortable...
Edited by .Stripes.
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 6d
Even though there are a million possible config settings as a very good guide the teins are very suited to smooth track work and this is where EDFC really can be tuned to suit and this is where the cost of a full tein set up would shine IMHO
But for straight out the box comfort and ride the shockworx are brilliant and made extremely well quality and finish wise
From your experience, Jet, do you feel the Shockworks would be as good on the track as the Teins is setup correctly? When I was chatting to Brett about all this he raised some interesting points form his experience: "If the Falcon is too flat you may not get the best out of the chassis. It needs some weight on the tyre. I had tested kits where the is nice and flat but is disconnected and the feedback from the wheel is lacking. You also do not need any bigger bars then the factory items as they just load the tyre too quickly and the breakaway in the wet quite fast."
  • Member For: 14y 4m 28d
I'd be interested in hearing from someone who has cut plenty of laps in both and can really comment. I think the teins have a higher spring rate which would explain why they are former on the street. If matched well with the damper settings this could translate to bring better on the track but happy to be proven wrong. In base form there's not much difference in cost between them.
  • flame magnet
  • Member For: 17y 20d
where's info on shockworx? google has plenty on shockworks- assuming not the same?
Also heaps of info in their section on AFF:
http://www.fordforums.com.au/forumdisplay.php?f=360
  • Member For: 12y 2m 11d
I put the teins in mine earlier this year and I'd have to agree with JET, they are brutal on the road. Smooth Tarmac roads are very bumpy things. In saying that, they are so amazingly good at the same time. No more lean, sticks to the road like glue and the feel of the car at speed, good speed is incredible.
Had to crop out front cos plate and iPhone :(
  • Member For: 19y 3m 23d
I have XYZ's and they have been fine so far
considered shockworks but didn't front the cash cos not racecar.
probably would have been just as happy with koni reds and king springs
