Vrdesign Member 42 Member For: 11y 24d Posted 17/07/14 02:35 AM Author Share Posted 17/07/14 02:35 AM And possibly a pic of the pwr internals? Link to comment Share on other sites More sharing options...
Stigmata Donating Members 235 Member For: 12y 9d Gender: Male Posted 17/07/14 08:31 AM Share Posted 17/07/14 08:31 AM Hey JulesI didn't get a chance to mate as it was so rushed just to get car on rollers. After the runs we did check the recorded temps of the PWR from previuos tune which had climbed to 40 odd degrees. The new coolers cold side pipes were totally cold, I think it would have been lucky to be over 20deg on a 15deg ambient day? I will head out to dyno again after drags and try and do some logging. I do have my PWR temp gauge which I should hook up too.Here's a pic of PWR extruded tube guys, probably the best extruded type tube and fin I have used. With that being said tube and fin technology has come a long way forward from extruded designs.Kind regards Jon 1 Link to comment Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 24d Posted 17/07/14 09:05 AM Author Share Posted 17/07/14 09:05 AM Massive difference in Internal surface area compared to the hypertune or plazmaman cores which use the thin offset style fins Link to comment Share on other sites More sharing options...
Stigmata Donating Members 235 Member For: 12y 9d Gender: Male Posted 17/07/14 09:45 AM Share Posted 17/07/14 09:45 AM Yep its a big difference from the Euro tube n fin designs. The Euro are so light with laser welded tubes and offset internal fin structure. You don't have to be Einstein to work out a lighter core will transfer thermal energy faster than a heavy cooler. Just like 2 pieces of ally plate the same size but one 2mm thick and the other 8mm thick, heat them up to same temp and the thinner will cool faster. That's all you want to do is transfer thermal energy from the charge air to atmosphere as fast as possible. Heres another pic of a Euro tube n fin. I have a pic of a core from Denso Europe floating around too I will try and findKind regards Jon 1 Link to comment Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 24d Posted 17/07/14 10:26 AM Author Share Posted 17/07/14 10:26 AM Any process west pics out there? Pretty sure it will look the same as the HDI core in one of the previous posts, but would be interesting to see. Link to comment Share on other sites More sharing options...
juggernaut Member 71 Member For: 15y 7m 13d Posted 21/07/14 06:56 AM Share Posted 21/07/14 06:56 AM That's a 600x325x100. Here is a pic of mine 3/4 the way through tube entry splayingKind regards JonRe the entry splaying, I sourced an extruded tube & fin cooler through A.R.E. (for my s15 some years ago) which had a CNC "venturi" plate made up which is welded onto the inlet side of the cooler. Basically it is an ali plate with radiused slots CNC'd into it. The slots line up with the entry tubes on the cooler and "directs" the incoming air into the cooler tubes. More or less with what you are doing however with a nicer radiused entry and which also extends around the ends of the cooler tubes. Food for thought and much easier than individually splaying each cooler tube....I would have thought. Link to comment Share on other sites More sharing options...
Stigmata Donating Members 235 Member For: 12y 9d Gender: Male Posted 24/07/14 09:50 AM Share Posted 24/07/14 09:50 AM Splaying the ends is very very easy and doesn't cost anything. I would think a venturi plate would have to be machined from at least 12mm alloy on a CNC mill and would add to the cost of the cooler. Having longer tubes which you can splay out doesn't cost anything at all. Would have been a K&J extruded core?Kind regards Jon Link to comment Share on other sites More sharing options...
juggernaut Member 71 Member For: 15y 7m 13d Posted 25/07/14 12:07 AM Share Posted 25/07/14 12:07 AM Hi Jon,I have the Adrad extruded tube and fin with longer ribs. From memory the venturi plate was around $150 extra which is peanuts in the overall scheme of things.Yes, the plate would be around 12+mm thick.Cheers, Link to comment Share on other sites More sharing options...
Stigmata Donating Members 235 Member For: 12y 9d Gender: Male Posted 27/07/14 10:35 AM Share Posted 27/07/14 10:35 AM Hey bud, yep $150 is peanuts. Got any pics?Kind regards Jon Link to comment Share on other sites More sharing options...
juggernaut Member 71 Member For: 15y 7m 13d Posted 27/07/14 11:53 PM Share Posted 27/07/14 11:53 PM Unfortunately, .....not of the inlet anyway. Link to comment Share on other sites More sharing options...
