Serangans Ba Mkii Xr6T
  • PC LOAD LETTER
  • Member For: 13y 3m 9d
Car looks awesome man ! What do you use the scangauge for ??
What pads are you using with the new rotors? Let us know how the rotor upgrade goes once you fix the wheel bearing.
  • Member For: 11y 4m 4d
Scan gauge was something I just got cause looked cool. Not all the functions work on it like l/100 but shows water temp, ignition timing, boost, and other various things that are sometimes useful.
Using bendex ultimate pads
Okay, so new front hubs on, took it for a test drive found a nice empty road to try the brakes out - my face almost fell off. Amazing difference, feels so much nicer than the stock setup!
  • PC LOAD LETTER
Good to hear the brakes are working well ! I forgot to ask, the computer setup in the car, do you have any install pictures for it ? Was it a pain in the ass to do ? I've seen others do something similar and wasn't sure if it was worth trying as a project.
Bascically, the hardest part was setting up the touch screen, which involved taking the icc out, taking it apart and adding a captivate touch screen in front, which plugs into the computer via usb.
Getting the interface from computer to the screen, that's using a video converter box from ASL, which also deals with my reversing camera so regardless I wanted that anyway. Then it literally just plugged in. Ran the wires and gave it a go. I haven't used it much because I've been busy doing various other things, but I should have it working properly soon - ill get a video of it when done.
Im just using a raspberry PI computer, so doesn't need much to run, just powered via a usb cable
@Panda Eyes, I like the fg rims too but still thinking they need to be changed, although I can't seem to find any nice aftermarket ones I like, the ba ones became track rims :)
On a side note, anyone know the thread of the falcon studs? is it M12 x 1.5 or M12 x 1.25?
  • PC LOAD LETTER
Oh that's right ! I forgot about the touch screen connection to the icc. I remember now seeing them sold on ebay and thought that would be the hardest part. Yeah chuck a vid or some pictures up of the system when you have time.
Cheers Panda Eyes.
went to leave uni today only to think 'wow, that ignition barrels feeling a bit loose' made it home checked it and the back had popped off. bummer.
Oh well perfect excuse to get the spring back to work again - the tab had broken off ages ago, so it was just something I had to manually, really scared people when I went to get work done on it, they thought they'd broken it.
Pics because I could
Various bits that fell out - one of those screws became the new tab for the spring to load against. Also two ball bearings not pictured here.
Ignition barrel, hard to see but theres a screw in there that replaced the tab for the spring back, had to drill a hole for it and taper off the head of the screw also.
Final result is, I have an ignition barrel that feels better than ever
Edited by Serangan
