Serangans Ba Mkii Xr6T
  • Member For: 11y 4m 12d
Hey guys,
Had this car a while now, thought I might throw some details up about it.
The basics:
  • 2004 ba mk2 xr6 turbo
  • 198k on the odo, now at 210k
  • 6 speed manual
  • premium sound system
  • velocity blue
  • Bought in october 2013
Started off like this,
post-72829-0-29616600-1402491411_thumb.j
Already had a aftermarket intercooler and cold side piping, as well as battery relocation, turbo side intake and a stupid 3" cat back exhaust.
One of my mates decided he wanted a dirty skyline that was located in launcestion, only problem was the engine had blown, so trusty falcon towed it down. Didn't skip a beat on the trip.
post-72829-0-76801800-1402492127_thumb.j
Left it in that form for a few months till I had the money spare to get it tuned as well as upgrade the following:
  • 60lb injectors
  • plazmaman valve springs
  • 4" dump
  • 4" cat
No real reason for the overly large dump and cat, but hey, why not.
Got it tuned at Howell automotive and it came back with 265rwkw and 573Nm of torque
post-72829-0-77778400-1402491605_thumb.j
The tuner there told me he wouldn't push it any further with the injectors I supplied as they were too poor of quality and didn't scale right and was causing excessive fuel usage (or maybe it was my right foot) as well as causing the car to stutter when starting as the spray pattern wasn't too good. So a few weeks later I came back with some bosch 968 injectors which he suggested, but this didn't fix my fuel usage, still returning 200km to a tank at most. Turned out the new O2 sensor that was installed when I got the tune had failed, so that was changed and suddenly I was getting 350-400km to a tank again.
Left it like this for a few months, then got sick of the rims, and a set of fg 18" honeycombs turned up on gumtree so I grabbed them while I could and got a new set of goodyear eagle f1 directions fitted and have been happy with this setup.
post-72829-0-67018700-1402492285_thumb.j
I've also re done the wiring for the battery relocation (previous owner did a horrible job), made a proper mount for the passenger side battery (previous owner strapped it down :ermm: ).
Recently installed a reversing camera using the factory ICC as the screen, and also have a raspberry PI sitting in the tissue box that displays to the factory ICC, raspberry PI does music, videos, games and soon to also do satnav. I've also got a touch screen overlay on the factory ICC, which hooks into the raspberry PI so no need for a mouse or keyboard.
In the last 2 weeks, I finally gave into the bearings that were starting the fail, so its now got new upper and lower control arm bushes, as well as new front shocks. Rear has got all new bushes, since the cradle had to be dropped anyway and sway bar links.
I also managed to find a stock xr6 turbo exhaust (twin 2.25") and have fitted that which is much nicer than the silly 3" cat back exhaust.
So yeah, that's about it. Im sure I've missed some of the things I've done to it but I've got plenty more I want to do. Just time and money are stopping me for now.
  • Like 3
  • 1 month later...
Re did the intercooler over the weekend. Previous owner had it being vl spec and causing the front bumper to warp and crack.
It's a HDI intercooler which doesn't fit as nicely as the process-west once but hey, its still working and temps are generally a few degrees above ambient, so I can't justify going out to get a new process-west intercooler (yet!)
Made up some new brackets to support it
post-72829-0-89101900-1405238953_thumb.j
This shows the clearance between bar and intercooler
post-72829-0-67413200-1405239135_thumb.j
Final product without the front bar
post-72829-0-68784600-1405238979_thumb.j
Also decided that while I had the car like this I'd change the clutch fluid
post-72829-0-76993200-1405239016_thumb.j
Came out with chunks! Cant see them in the photo though
Cheers MattyP
Been reading what most people have done to get into the 300rkwk club so basing the following changes off that.
Im getting a retune in the coming weeks.
Planning to change the fuel pump to a walbro gs340.
Removing the factory crossover pipe and replacing with a process west one to help the flow.
Considering a turbosmart actuator with 7psi spring but unsure if I need to worry about this at the moment.
yeah got valve springs, injectors, dump pipe and cat done last tune :) this is just smaller stuff to get done to ensure is running safely etc.
should hold if its had all that work done :)
If it wasn't a daily I'd go all out on it. But I'm only chasing 300rwkw and I'm currently at 265 (so almost there)
Plenum yeah well it works and I don't really mind it, its the cross-over pipe that I hate currently.
Haven't thought about modding the turbo at all and I don't really think theres a need to with the power I'm chasing. If the turbo it's self dies then I'd consider something then.
  • 3 weeks later...
Upgraded front and rear rotors recently,
DBA t3 4000 on the fronts (also went to BF type, so 322mm fronts now)
DBA t2 on the rears
Picture of the rears :wwww:
post-72829-0-07958400-1407041248_thumb.j
They look amazing, havent had much chance to try them yet cause wheel bearing decided it was time to go, so have to fix that now.
New fuel pump also installed, Walbro GS340 just cause it seemed like a good idea. And kinda glad I did cause this is what the in-tank filter looked like...
post-72829-0-17321600-1407041291_thumb.j
Also found a place to mount my scan gauge tool
post-72829-0-05950900-1407041127_thumb.j
Also gave it a bath just cause it was a nice day.
post-72829-0-86503100-1407041161_thumb.j
