  • Member For: 11y 9m 18d
Hi all I have a BF Tornado manual, and I got the driveshaft rebuilt today, (costing 950, is that reasonable?)
And the guy that did it recommended raising my gearbox to level out the angle of the shaft to stop the centre bearing flogging out because my ute is lowered, is this common to do this?
Because driving home I noticed my gear knob is slightly higher due to gearbox raise, and also a slight rubbing noise which irritates me as I like my F6 to be smooth! ha.
Just wondering on your thoughts!
I am getting new leaf's put in soon and getting the rear raised back up a little, and he said to bring it back and he will check the angle again for me, basically I just went with what he said because he is a drive line specialist, but my concern is the slight rubbing noise coming from my gear stick..
Cheers!
Edited by boo-st
https://www.fordxr6turbo.com/forum/topic/88485-bf-gearbox-raise/
  • Dropping a turd
  • Member For: 17y 7m 24d
I suppose as long as the gearstick doesnt hit the roof it should be ok.
But seriously take it back so he can sort the knocking/rubbing issue.
Bet your shifter isnt higher than mine.
  • Menace
  • Member For: 14y 1m 30d
How long of a throw do you have?
Also what brand short throw/shifter kit are you using?
  • Moar Powar Babeh
  • Member For: 19y 8m 28d
"yes"
Console needs to come out and gearbox plate needs to be removed (nuts need to removed from under the car) then it's a cake walk
  • Member For: 16y 6m 12d
  On 11/06/2014 at 1:42 AM, ms700 said:
Here's one from left field - can the mal wood shifter be installed 'easily' with the box still fitted?
I did my old ute with the box still in, from memory it wasnt too painful...
  • Like 2
  • Dropping a turd
Mal Wood with hurst stick.
Length gives leverage and strong spring centers shifter. So its smash straight up for 3rd and straight back into wheelspin.
  • Menace
  On 11/06/2014 at 3:49 AM, arronm said:
Box needs to be lowered slightly to get to screws. But its easy
Or be a grub n drill some 13mm holes
