Waris93 New Member 4 Member For: 10y 11m 4d Posted 08/06/14 04:19 PM Share Posted 08/06/14 04:19 PM Hi everybody, this is my first post here, been searching and reading stuff for a while, but I have too many questions in my mind so thought will be good idea to post it here.I just bought my first turbo car last week, Its 02 BA XR6T but with fair few K's its got 260 thou K's but girl I bought it from her brother was mechanic and he said he recently replaced turbo and valve springs on it, its also got nice exhaust sound too.I was reading a post somewhere about cleaning boost control solenoid with wd40 and when I went to do it, hose which goes from waste gate to solenoid was disconnected and its very loose so after spraying wd40 I used cable tie to hold it, At what RPM I should be expecting boost to come ? max psi I could push is 5 but I noticed boost is not coming easily, also when it hits 5psi it doesn't hold that boost and I have to put my foot down even further and then it rebuilds again, so where should I start looking for problems ? I tightened all manifold bolts when I had my heatshield off, but didn't had right tool for turbo bolts so couldn't check that.Also I noticed my vacuum on idle sits at around -15 to -16 and doesn't go any lower then that, my mates wrx sits at around -20 so is that alright ? It also idles rough at lights when warm, runs fine when cold, also if I move my shifter to N it idles fine, My fuel consumption is also very high its showing 20.1 L 100/KM and I have only hit boost few times.My rwc also says "rear diff mount cracked" and I also noticed lots of oil around diff, how much should I be expecting to pay for that ?I got my car booked on Wednesday for service, So they'll be changing oil, filter, wheel balancing, coils, plugs, and possibly fuel filter too.Rough idle is not a big issue atm, only thing I am really worried about right now is diff, because its leaking oil so would it be safe to drive ? I also hear clunk noises when going over small bumps so it could be diff too ? Sorry for such a long post, I am so confused right now where to start from but any help is appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/88469-ba-xr6t-not-holding-boost/ Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 15d Gender: Male Location: Brisbane Posted 09/06/14 05:41 AM Share Posted 09/06/14 05:41 AM Well yeah it would have been smashing my date before without the wastgate actuator connected at all. 5psi dropping off sounds about right for a stock ba. Your idle vac does seem a bit low mines around 20. As for the diff bush it's a cradle out job so there is a bit of labour in it. Link to comment https://www.fordxr6turbo.com/forum/topic/88469-ba-xr6t-not-holding-boost/#findComment-1477339 Share on other sites More sharing options...
Future Donating Members 116 Member For: 14y 2m 1d Gender: Male Location: Brisbane Posted 09/06/14 07:24 AM Share Posted 09/06/14 07:24 AM (edited) I just had a heap of work done to my ba xr6t and the tune was set for 15psi, the mechanic warned me about having a sticky actuator.I would put my foot down get 15psi then straight back to 6 and sometimes wouldnt even hit the 15.Now have turbo mod done with 10psi actuator and holding boost all day long.Edit: Also on idle my gauge reads between -18 to -20 vac Edited 09/06/14 07:26 AM by Future Link to comment https://www.fordxr6turbo.com/forum/topic/88469-ba-xr6t-not-holding-boost/#findComment-1477366 Share on other sites More sharing options...
Waris93 New Member 4 Member For: 10y 11m 4d Posted 10/06/14 09:24 AM Author Share Posted 10/06/14 09:24 AM Getting it serviced tomorrow and for boost I am pretty sure its my gauge playing up, I can hear my turbo spool, I can feel the boost but my gauge moves and drops, but power is still there. Thanks guys will let you guys know. Link to comment https://www.fordxr6turbo.com/forum/topic/88469-ba-xr6t-not-holding-boost/#findComment-1477578 Share on other sites More sharing options...
