  • Member For: 11y 5m 10d
TIP: Dont spend 2hrs stuffing around requesting pids with the engine off. You will end up with a flat battery. I even had the icc and ac off.
  On 01/07/2014 at 8:00 AM, Sergeant sarcasm said:
That why you go led barnz
Tried to make heads and tails of that like 6 times, just cant lol. Wat chu talkin bout Willis
  • 2 weeks later...
  • Member For: 12y 10m 9d
This is how I've set mine up. Haven't been able to get ZF trans temp working or engine oil temp obviously. 3 values come up for transmission temp but one sits at -40°C and the other two just sit at ~193°C.
Gear indicator doesn't work completely either, it only logs the first 4 gears.
Also I am using the white OBDII adapter with auto-off that was linked earlier in this thread (it's a KWOK branded one) I'm finding that it turns off fine but it won't turn on with the car unless I press the button on it, which isn't so great when stays plugged in behind the panel.
post-52142-0-16936600-1405145522_thumb.j
Just a teaser but I think I'm real close just not 100% on the equations. EOT and ZF trans temp after 20 mins of idle. Pretty happy with temps in relation to coolant.
