barnz Member 3,047 Member For: 11y 5m 10d Gender: Male Location: Brisbane Posted 24/06/14 08:06 AM Share Posted 24/06/14 08:06 AM On 24/06/2014 at 1:37 AM, alltourque said: Just above the oil filterthought that was just a pressure switch, turns out it is a combination and does EOT aswell. Cheers 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1480671 Share on other sites More sharing options...
qwigybo Member 288 Member For: 18y 11m 27d Location: bendigo home of SFA Posted 24/06/14 01:01 PM Share Posted 24/06/14 01:01 PM This is a cool thread. Been thinking about getting torque and obd2 connector for a while. Definitely getting one now Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1480727 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 5m 20d Gender: Male Location: Gold Coast Posted 27/06/14 01:53 PM Author Share Posted 27/06/14 01:53 PM Got the Scan Plug In the other day and had a geez at it today.. soooo many options to look at as opposed to the regular gauges.. prob too many for me lol :Dalso clipped off the adapter and have the plug now permanently connected.. no worries with battery drain at all.. Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481421 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 26d Gender: Male Location: Townsville Posted 28/06/14 01:46 AM Share Posted 28/06/14 01:46 AM Battery probs will only happen when your battery is getting on (3yrs+) and you don't drive or start the car for extended periods (1wk) like myself!I'm not sure on the age of my battery as I've owned the car (F6X) for 2yrs now so will guess that it's atleast 3yrs old and when I try and start it after a week or so the starter will just lag then crank slow or nothing and on the second try then it will crank over...Funky sh*t can also happens with the low battery like the speedo or tacho won't work, rear door will not open via it's button but all is good once the car is stopped, key removed and then restarted again.I'll get a new battery one day!Jibbering there so now I'm off to bunnings and I'll check that trans temp code while I'm out for you fellas also...If the car starts!!! Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481481 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 21d Gender: Male Location: left right out Posted 28/06/14 04:29 AM Share Posted 28/06/14 04:29 AM (edited) I found the trans temp in the list you get when setting up a new 'gauge', highlighted in green here-Not so sure about the accuracy of some of them though, according to this my cat is running at 440 celcius! Edited 28/06/14 04:30 AM by hawlass Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481499 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 26d Gender: Male Location: Central Coast Posted 28/06/14 04:51 AM Share Posted 28/06/14 04:51 AM I found even though I told it to be in celcius it still showing it in farenheitWhat a ridiculous unit of temperature Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481506 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 10d Gender: Male Location: Brisbane Posted 28/06/14 05:33 AM Share Posted 28/06/14 05:33 AM Did you change your units to metric in you vehicle profile? Cause if you change the unit in the pid itself that doesn't work. Torque will convert units automatically depending on your preference. 82 degrees seems right, should be close to coolant if your still running the heat exchanger. Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481516 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 21d Gender: Male Location: left right out Posted 28/06/14 05:59 AM Share Posted 28/06/14 05:59 AM Yes I have set relevant perameters to metric in torque. The trans and engine coolant seem to stay within a degree or two of each other. It would be interesting to see how a car with a fluid to air trans cooler logs, temp difference wise.After asking uncle google he reckons a cat needs to reach 430 C to convert nasties properly, so its normal I guess.Mental note, dont park in long dry grass. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481517 Share on other sites More sharing options...
Spyathe Donating Members 872 Member For: 11y 6m 1d Gender: Male Posted 28/06/14 06:49 AM Share Posted 28/06/14 06:49 AM Are you guys in FG's? I don't get cat temp, and I had to manually input the formula to get the trans temp to work, not sure if the app has been updated recently though Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481527 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 21d Gender: Male Location: left right out Posted 28/06/14 07:14 AM Share Posted 28/06/14 07:14 AM BF2, downloaded torque a week ago so newest version I guess? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88462-android-app-torque-tips-and-tricks/page/8/#findComment-1481531 Share on other sites More sharing options...
