  • Member For: 18y 8m 30d
  • Member For: 8y 11m 11d
  • Gender: Not Telling
  On 29/08/2016 at 1:37 PM, ROB83R said:
Got my elm327 dongle today.
Been mucking around with torque on my Prado and the xr6. Only just cracked the surface.
I've got the full version of forscan but it won't recognise my adapter.
Any ideas what I'm doing wrong?
Expand
Rookie mistake.
I had torque running which was stopping forscan. Close torque turn of bt and let forscan find it and all is good. There's so much stuff on forscan. Still like torque better.
Which is is more accurate for trans temps? There's a few to pick from on forscan. One sits just below coolant temp and another is double that. Not sure which too believe.
Boost is another that has me I <3 Bananased. I think the standard global torque pids are pretty accurate.
  • 1 month later...
I'm not using the Ford specific pids. Find them to be sh*t.
Anyway I was wondering what you guys are using as the boost correction? I've had it set at 1 and was barely seeing 4psi. Set it at 0 and I hit 8psi. Fairly certain standard is somewhere in between these 2.
  • 6 months later...
  • New Member
  • Member For: 8y 2m 24d
  On 10/07/2016 at 10:26 AM, bad inferno said:
Found out how to create my own gauges although its a shame I cannot change colours between night and day.  However these now match the dash :)  I can send gauge theme to anyone who wants it...  although XR50 logo is part of the background which can easily be removed.
Expand
I'd be interested in getting a copy of your gauge setup if I can...
  On 30/05/2016 at 8:36 AM, bad inferno said:
Thanks for the tip on getting oil temperature working,  here is my installation.  a $98.00 tablet velco onto a perspex plate which replaces the tissue box.
thanks for those that provided the work on oil temp PID and Calculations....
Expand
How do you have that GPS attached to the ICC lid?
  • Member For: 19y 8m 15d
GPS: I took the suction cup and locking ring off the foot of the mount and it actually has three encapsulated brass threads behind the suction cup when its removed.  Then its pretty simple to just use three screws up through the ICC lid to secure the mount.   A larger hole in the ICC lid allows the USB cable to be fed up through.  This larger hole for the usb cable  is covered by the mount when you screw it down.  You can see my cable in the pic.
Edited by bad inferno
  • 1 year later...
  • New Member
  • Member For: 9y 10m 4d
Hi guys,
hoping someone can help with the EOT gauge on the Torque App.  I have downloaded the Ford PIDs and I have the Transmission Temp working just fine. I have tried the PID 221310 and I do not get any connection (so this is not a formula problem)  I tired to change the PID number to 220907 and that did not return anything either, so anyone help point me to what I need to do to get the Engine Oil Temp to work? I have an FG Mk2 XR6 n/a Auto and using Torque App and a generic Android 7" Tablet.
Cheers n beers, Mick
  • 6 months later...
  • WOT?
  • Moderating Team
  • Member For: 12y 2m 5d
Has anyone got settings (pid's etc) on their torque app for an FG XR6T auto they could recommend (and any other models)?
I'll add any "complete" setups to the 1st comment as a "cheat sheet"
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 20d
pretty sure they're just all in this thread... so have a read and fix up the first post :P
