  • Member For: 11y 13d
forscan would be my pick. but you have to pay for it
http://forscan.org/home.html
and to benefit from all its features, you'll have to modify the obd2 device
  • Moar Powar Babeh
  • Member For: 19y 7m 7d
  On 16/07/2015 at 2:06 AM, Tocchi said:
Guys, what is the best APPLE obd2 program to use? As TorquePro is not available for crapple
Cut Apple loses $80 android tablet.
Move on with life.
http://www.shoppingsquare.com.au/product.php?id=413976&n=3283
Just bought one of these for my 2yr old to destroy. Quality is quite good for the price and will run torque
  • Sandtrap Motorsport
  • Member For: 16y 5m 5d
What needs to be modified to access which features? Lol
Mostly looking to view/clear codes
Possibly view fuel trim / lambda values
the elm327 adapter needs to be modified to access all the ford PID's
this explains it
http://forscan.org/forum/viewtopic.php?f=4&t=4
  On 16/07/2015 at 6:40 AM, Ralph Wiggum said:
Are you sure that applies to aus fords?
Yep Sure does. I've done it to two elm's, works a treat
  • Moar Powar Babeh
What model car and what additional pids (or modules) are you picking up?
  • Moar Powar Babeh
I'm interested so see your results as i've scanned numerous ba/f/fg and have never had the MS-Can prompt.
  On 16/07/2015 at 7:26 AM, Ralph Wiggum said:
I'm interested so see your results as I've scanned numerous ba/f/fg and have never had the MS-Can prompt.
have u used forscan?
with HS-Can only(ie select no when it asks if the elm has MS-can switch)it recognised the following modules
TCM
PCM
OBD2
ABS
RCM
HIM
with MS-Can(select yes, but you need the switch modification) it recognises all the above plus
FDIM
BPM
AIM
PAM
ACM
BEM
IC
