  • Member For: 11y 4m 30d
Here's my zf trans temp, car is off and has been for 20mins since getting home from about an 1.5hr trip.
Here is the pid
Set your units to Celsius in settings. Happy days
  • BOOST
  • Moderating Team
  • Member For: 21y 7m 14d
This is how I've set mine up. Haven't been able to get ZF trans temp working or engine oil temp obviously. 3 values come up for transmission temp but one sits at -40°C and the other two just sit at ~193°C.
Gear indicator doesn't work completely either, it only logs the first 4 gears.
Also I am using the white OBDII adapter with auto-off that was linked earlier in this thread (it's a KWOK branded one) I'm finding that it turns off fine but it won't turn on with the car unless I press the button on it, which isn't so great when stays plugged in behind the panel.
Just be careful with that profile. I ended up with a bit so screen burn on my s4
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 15d
Ah fair enough I was wrong
I never thought they could get ghosting but there you go
  • Member For: 11y 2d
barnz,
I used your formula for EOT, seems to work ok
thx
have figured out the tweeks needed to have it read correctly? I.e not out 10c
barnz,
thx
Ive been playing with the divider, increasing it brings temp down, 76-78 looks better but im still guessing. What I really need to do is get a laser thermometer so I can monitor the temp through a full cold - hot heat cycle. Just getting it spot on at say operating temp doesn't necessarily mean its accurate throughout the entire range.
Exhaustive searches of the interweb have turned up some helpful information but no magical answers. Aside from getting a tool that has all the extended pids and hacking it...somehow. Working out the equations is going to be very hard. Identifying the pids themselves (220907 ect.) is a piece of piss in comparison.
  • MattyP
  • Cruise Control
I haven't been to my father's place yet to tax is infrared thermometer.
As soon as I can ill get it done
  • Like 2
ive got access to a infrared thermo from work.
so what do I need to change in the equation to test?
Formula: (((A*256)+B)*5)/72
just the end number?
You may find playing around with that is all it needs. Or the whole *5)/72 is wrong entirely lol. Its just the closest I have gotten.
