Ford Blue Fpv Brakes On A Xr6T Ba With 298Mm
mobisam999
  • Member For: 10y 5m 16d
Hi all
I have the standard ba brakes fitted (298 mm front 303mm rear)
I've come across the blue fpv calipers and want to fit them on my vehicle, and I'm running stock 17 fg wheels.
Will I need brackets for the caliper? And a new set of wheels?
One more thing I should add...The disc's will now be 325 mm front and 328 mm rear
  • Member For: 12y 4m 11d
Should bolt straight on, well did for my FG.
The 328mm rears will need the backing plate trimmed, which is a simple job.
Not sure if you will need to change brake lines on the rears.
Believe the 17's should be fine but probably get someone to confirm this.
  • Dropping a turd
  • Member For: 17y 23d
17 fine. Calipers have their own brackets. Must use brake lines that come with the blue calipers
Edited by arronm
Hi all
I've come across a set of blue fpv brakes and wondering if it will need any extra mounting parts like brackets to mount on to my vehicle (ba xr6t with the standard brakes) , which currently has 298mm discs. New discs are 325mm. Will these fit standard ba 17' alloys?
Please help!
  • Dropping a turd
You need the calipers and the 325mm discs. No extra brackets but you need the brake lines that come with the calipers.
17 inch rims are fine. But they are the min size.
  • Member For: 16y 11m 25d
I liked your response better in the other thread.
Edited by -SteveR-
Edited by -SteveR-
It's when they change something, it's a glitch in the matrix.
