Hybrid Gt3540
P_BA_XR6
  • Member For: 16y 5m 16d
I put a 66mm gtx wheel on my 3540 and seems to be bit laggy. I would have thought it would of worked out. But apparently not it seems laggy.
It's .7 compressor housing with 66mm to factory 68mm rear wheel in a the factory 1.06 rear housing. It doesn't make punchy boost till about 4000 like the factory turbo does at 2500/3000.
So I'm wondering what I should do. Do I try smaller rear housing like .82 or buy new turbo like precision 6235.
But I don't know if it will make the power I want. I want 450 but later probably close to 550rwkw. With boost coming on around 3000 or am I just dreaming. I've considered mta900 or 6266 but I don't know how responsive they are.
So if anyone could give me some suggestions I would appreciate it
Sent from my iPhone using Tapatalk
  • MattyP
  • Cruise Control
  • Member For: 12y 6m 13d
What's the exact spec of the wheel?
Who did the tuning?
What are you supporting mods?
When does it spool up?
Most gt35r/billet t04z turbos are good for 450 easy on e85 and sound amazing
With most of these things we need more details
Plazaman hot side 2.5 to 2 3/4
Plazaman 2 3/4 Cold side
Nizpro big big cooler
4in intake Plazaman
Plazaman plenum
Duel feed fuel rail Plazaman with twin 8an lines feeding either side to rail with check valves on each fuel pump
dual Bosch 044s from 1 ltr surge tank
2000hp fuel reg turbo smart
Id1000s
400lph intake fuel pump
High mount 50mm steam pipe
50mm external gate connected back in near the gear box
4in custom dump pipe
4in cat with 5in body
4in to the back of gearbox then Twin 2.5 from back of gear box to tail tips
possibly changing the rear section from twin 2.5 to twin 3in soon as I'm putting 4link in and my exhaust will be in the way so may aswell make it better
Going from single plate option 4 to twin plate this weekend
6 speed Malwood manual
Port polished head
1.1mm larger ferra valves
Atomic oil pump
F6 short block
(Regretting not building motor)
I think that's it
Edited by P_BA_XR6
