genuine honest person Member 2,769 Member For: 11y 5m 5d Gender: Male Location: near brisbane Posted 19/03/16 07:14 PM Author Share Posted 19/03/16 07:14 PM On 19/03/2016 at 0:33 AM, Ralph Wiggum said: Your engine mount mount is upside down. No they are the corect way .technico have changed the way they get fitted now .I got mine rebuild by him for $50 including delivery .he also gave me a heat shield for the turbo side. thanks for your concern .my only worry with them is that apparently they couse bolts coming loose due to the non dampening efect ? On 19/03/2016 at 11:48 PM, arronm said: Has your sandwich plate got a thermostat, and where are you fitting the cooler. Why no fan?? that's how geoff had his fitted .bought his set up of him .no the sandwich plate has no thermostat. I thought the cooler alone would be ok for the engine oil cooler as it gets air traveling onto it at any track events . The cooler used to be set up with a fan but I am using it th cool my automatic transmission .please explain the thermostat at the sandwich plate. .is that so the oil reaches corect temperature before it by passes through the cooler.never seen one before Also noticed that its a pull only fan and geoff had the polarity the oposit way so the fan would run the other way .thought that would not be good for the fan so I changed it on my automatic transmission cooler the other way It does say black is positive on the fan but that's not how he set it up I am running a oil temp guage to keap an eye on the temp had a hard time to remove the allan keyed grub screw as it was made out of aluminium see geoffs had a spacer ,can make out if looking closly. I had no idea that I needed it before I installed it I got that hole set up for $600 so deffenetly worth it as geoff paid $1300 for it he said to me with all the fittings and fan etc Have found some on e bay .no idea that they existed lolthis next one is a hell of a lot cheaper .will this one be ok as the other one is close to 400 dollars and are the fittings an 10 suitable ? Ok so I will need the 1/2 npt to suit is that corect ?I can see how they work now ,oil only gets restricted to 10 % flow Would I be better of also getting one for the automatic gearbox .thought that they run at 70 Fahrenheit and not 80 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582900 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m 6d Gender: Male Location: Perth Posted 19/03/16 10:52 PM Share Posted 19/03/16 10:52 PM I use derale 25782. But it doesn't have ports for temp gauge. You need to keep the engine oil above 80c 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582913 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5m 5d Gender: Male Location: near brisbane Posted 19/03/16 11:04 PM Author Share Posted 19/03/16 11:04 PM Thanks a lot for that info .so will they be ok to use for the engine and automatic? Diffrent size to suit the an10 and an 6 for the trans Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582914 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 13d Gender: Male Location: Brisbane Posted 19/03/16 11:15 PM Share Posted 19/03/16 11:15 PM great update Ill take a turbo side and battery relo for an fg thanks haha...looks good also like the shroud/duct thing behind the cab 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582915 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 20d Gender: Male Location: Perth Posted 19/03/16 11:40 PM Share Posted 19/03/16 11:40 PM Good to see you're persevering Gunna! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582917 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5m 5d Gender: Male Location: near brisbane Posted 20/03/16 01:47 AM Author Share Posted 20/03/16 01:47 AM Thanks for the positive feed back .took me enough to post anything on here about my car not sure if the crimsafe stainless would flow more or the larger perferated sheet .think the stainless would 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582925 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 13d Gender: Male Location: Brisbane Posted 20/03/16 02:30 AM Share Posted 20/03/16 02:30 AM I think the mesh is over the top, its well protected without it, mesh would maybe stop a bird lol..The way it is nothing coming off the road will hit it. Im surprised you went to the effort of making the shroud/scoop and angling it into the airflow. Your not doing things by halfs.. have you done one for each side? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582932 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5m 5d Gender: Male Location: near brisbane Posted 20/03/16 02:37 AM Author Share Posted 20/03/16 02:37 AM Thanks barnz . I will for safety reasons put some mesh on it also hides it a bit.take a look at the photo the bottom sticks out a good 70 to 75 mm the angle of the cooler is about 22 degree or 68 degree which ever you understand also protecting if the tyre picks up a rock from the other side .still not finnished but getting there On 20/03/2016 at 1:30 PM, barnz said: I think the mesh is over the top, its well protected without it, mesh would maybe stop a bird lol..The way it is nothing coming off the road will hit it. Im surprised you went to the effort of making the shroud/scoop and angling it into the airflow. Your not doing things by halfs.. have you done one for each side? that's maybe why I expect the same when I get stuff done to my car . I know I am fussy as but so I am at work . mad max is on foxtell .stoped work to watch it I might run this waterless coolant in my engine ,anyone using it .its like $500 for a full fill up On 20/03/2016 at 1:30 PM, barnz said: I think the mesh is over the top, its well protected without it, mesh would maybe stop a bird lol..The way it is nothing coming off the road will hit it. Im surprised you went to the effort of making the shroud/scoop and angling it into the airflow. Your not doing things by halfs.. have you done one for each side? No only one side as the battery is on the other side that is where the new location for the sender in the dump pipe Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582933 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 7m 12d Gender: Male Location: Melbourne Posted 20/03/16 10:51 AM Share Posted 20/03/16 10:51 AM I might run this waterless coolant in my engine ,anyone using it .its like $500 for a full fill up I have done a bit of reading on this stuff before, it's actually makes your engine run hotter than a normal coolant mix As you have installed an oil cooler, which will aid your engine cooling capacity a massive amount I think you should stick to a good quality glycol/demineralised water coolant I'm not saying it's a bad product, it's just not a miracle fluid, that makes your car run cooler 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1582998 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 5m 5d Gender: Male Location: near brisbane Posted 20/03/16 10:57 AM Author Share Posted 20/03/16 10:57 AM Will stick to the penrite stuff ,green stuff Found my new tyres awsome still 16 inch .and they do fit onto a 7 inch rim .now that will be enough traction they will look good on these so yes they will fit Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/71/#findComment-1583000 Share on other sites More sharing options...
