  • Member For: 11y 2m 17d
Thanks. Thought it may help , was worth asking as it used to work great on vl turbos etc . Will not worry about it then
  • Member For: 8y 10m 26d
  • Gender: Not Telling
Yeah back in the day when e85 was a distant dream.
On 98 it'll work wonders. But for that money you can buy a good pump setup and just run 85.
Plus it's gotta be setup with a tune. If you run out you're farked till you can top it up.
Edited by ROB83R
I have a serge tank etc to suit E85 .yes will save my money and spent it on other stuff
  • skids
  • Member For: 12y 3m 17d
  On 20/11/2016 at 9:25 AM, genuine honest person said:
255 40 16 mickey Thompson .should be not to bad
Expand
should be right after a skid hahah.
are you close to E85 stations? other than the cost to convert, it's about half an hour to the nearest station with e85 from me :(
Yes its about 45 min drive for me .but I will set up my garage with some cans and some sort of syphoning set up
  On 20/11/2016 at 9:38 AM, genuine honest person said:
Rather ask so I do not buy stuff that is not needed .
Expand
Smart man.
Do you plan on going e85 permanently or running 2 tunes?
Johnny just grab some jerry cans and stock up.
Mine is only 5 minutes away. Actually on the way to work.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 15d
Water meth kits are a good bang for buck modification no question as the job it does it to purely cool the intake temps dramatically and with cool stable temps power generation is quite substantial
upwards of 30rwkw can be had off of a correctly set up and tuned kit and is really a step sideways if you can't afford a big cooler and other hardware ( typically ) but even with a "banging" set up even on E85 watermeth will still reduce intake temps dramatically so there's still a gain to be had especially if you live where ambient temp is typically north of 30* and humidity up there as well
anytime we can reduce IAT's there's gains to be had !
for $1100 plus tuning time/costs I probably wouldn't bother for what you want and can be achieved without it ;)
