barnz Member 3,047 Member For: 11y 4m 25d Gender: Male Location: Brisbane Posted 31/10/16 11:02 PM Share Posted 31/10/16 11:02 PM Last time im gonna waffle on bout it... I think a email tune so it will start and a rev limiter so you can check for leaks take it for a drive shake it down put some kays on everything is a mint idea. Hes probably going to end up stuffing around with sh*t like actuator preload etc... You may aswell check over and rectify anything you can yourself before it even gets there save him the time and frustration...Will quickly knock the wind out of his sail if he has to spend heaps of time on stupid little things that could have been sorted before it arrived. You do such a great jov there probably wont be much but its worth a shake down imo 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619110 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 10m 26d Gender: Not Telling Location: Radioactive wasteland Posted 01/11/16 01:00 AM Share Posted 01/11/16 01:00 AM Stop talking sense barnz... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619130 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 17d Gender: Male Location: near brisbane Posted 01/11/16 05:48 AM Author Share Posted 01/11/16 05:48 AM On 31/10/2016 at 11:02 PM, barnz said: Last time im gonna waffle on bout it... I think a email tune so it will start and a rev limiter so you can check for leaks take it for a drive shake it down put some kays on everything is a mint idea. Hes probably going to end up stuffing around with sh*t like actuator preload etc... You may aswell check over and rectify anything you can yourself before it even gets there save him the time and frustration...Will quickly knock the wind out of his sail if he has to spend heaps of time on stupid little things that could have been sorted before it arrived. You do such a great jov there probably wont be much but its worth a shake down imoyes I will get a save tune done barnz that is a great idea lol. But that doesn't help me at all as I want the yella terra flex plate doweled and whatever they do to keep it from coming loose . Also I have this latest model gearbox that has no gears ,that does not even need oil . I am also not going to use a cat as that is to restrictive for my set up ,rather have it come straight out of the dump pipe . Yes I am not able to drive it there itscgot to get there on the back of a tow truck and as I asked jamie to finnish fitting the flex plate and box . Then they can also fit the rest of the exhoust as a standard jouner will not fit as the cat has not been welded to any flanges at all .they do not only tune cars they work on them as well. One thing I will refuse to fit is the gearbox as that is a carnt under the car to do , no thanks it was hard enough to fit the gutted gox Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619157 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 4m 25d Gender: Male Location: Brisbane Posted 01/11/16 05:57 AM Share Posted 01/11/16 05:57 AM fark man no wonder he is saying no go till next year your going to drop him a 95% finished but kind of untested build? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619158 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 17d Gender: Male Location: near brisbane Posted 01/11/16 06:03 AM Author Share Posted 01/11/16 06:03 AM Lol its all in my thread if you read it page to page .has always going to be that way . And he knew that also . 4 hrs and the box is in .on a hoist it is no problem at all .then the exhoust another 3 hrs max .yes that's a days work and all done . For me to do the exhoust I would have to trailer it to a shop first then get it welded . Rather get jamie to do that instead . Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619159 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 4m 25d Gender: Male Location: Brisbane Posted 01/11/16 06:11 AM Share Posted 01/11/16 06:11 AM hmmmm, you you done a fkn mint job of mocking up all the bay pipe work and having it welded, how is the exhaust different. For most I would say you will fark it up but you have proved that you dont lol, coz german.Want a hand putting the box in?I mean I was here at the fkn start to help get the first incarnation running so im happy to come in and the end take all the cream lol... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619161 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 17d Gender: Male Location: near brisbane Posted 01/11/16 06:24 AM Author Share Posted 01/11/16 06:24 AM I rather pay somone to do that .as the flex plate has to be drilled for Dowling to be fitted .itsca 10 mm thick flex plate from yella terra . The exhoust could not be much for him to do .he did say last time he would be able to weld one up with no problems . I know I could do the exhoust but why do it if somone can weld it in place there as it moves when you weld it when its not bolted up .I think I have done enough on the ute and itsctime for professionals to do the last bit of it . Thanks for your help barnz but I also got to look after my back as I have a permanent injury that I rather not make worse . That could put me of work for a long time .rather not risk that as that could meen the end for me . The injury I have could paralyze me from waste down . I sustained the injury at work about 10 years back and work cover did nothing . Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619162 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 17d Gender: Male Location: near brisbane Posted 02/11/16 10:39 AM Author Share Posted 02/11/16 10:39 AM Happy as , jamie booked me in in the new year to do the rest of the work before he will give it a run in tune . Gives me some time to sort everything out before I take it to him in 2017 . 4 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619417 Share on other sites More sharing options...
Elusivef6 Member 51 Member For: 8y 8m 20d Location: SE Queensland Posted 03/11/16 05:55 AM Share Posted 03/11/16 05:55 AM My car has just comeback from forced and its brilliant. Close to 600hp Definitely better then my first tuner. Highly recommended. Worth the wait 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619555 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 17d Gender: Male Location: near brisbane Posted 03/11/16 06:19 AM Author Share Posted 03/11/16 06:19 AM Yes that is the most important of the whole build ,a good tuner like jamie .I can wait its no problem to me Looking good . Are you taking it to any events ? Torque time etc Link to comment https://www.fordxr6turbo.com/forum/topic/88393-327-rwkw-760nm-xt-one-tonne-ute-was-a-v8/page/137/#findComment-1619559 Share on other sites More sharing options...
