  • Member For: 11y 2m 26d
Lol thanks .they only ever see us when they need somthing , but that's cool with us
  • Like 2
No time to work on the car ,just a small step ahead this weekend again .was at work working out a job . d1cfe896b08f7899b7cd45a6c34abdca.jpg4794f6183c575e86cec31892281f3042.jpg8c1d18df41555f63a1b115d952924666.jpg18b8c7c0182c03949c09394e2fa8a0e9.jpgd0427e0fbcdf3e7812efa2d225fd9ae4.jpg60824526ba8ab108f0250967d18f7c50.jpg576ef09b7b14ac3dc31bd236c843a721.jpg743f2aedf7850567e680590ef5d3cfff.jpg5d529e71be54a2abd0cf35d85e00c991.jpgdcdc494e62a202cd3b8fc1c58afe5086.jpg08e8cc06c17f04d8f255d25379ed68dd.jpgb075d3d1facec2df001431ca133a3341.jpg7ceacdcba155fba1fe41f3788de808cf.jpggot to make a catch can but still deciding on the design of it .also have a nother airoflow filler cap coming for the catch can so I can see the levels ,drain plug and fittings . Time is what hurts me the most
Have a question how do I change over to suit an 8 fitting to the serge tank as the fitting is joint to the inside pump hose which is fitted with a hose clamp .what I would like to know is is there a special fitting to go on from process west or can I get one at most places .the other thing I thought of doing was just to use a barb fitting with a an8 fitting and then use the braded line ,I know that is a bit rough but would still work I thought . Ps that is a brand new serge tank and the dirt that is inside is a fair bit .it looks like aluminium filings etc ,that entering the injectors would not be the best I do know it has a filter attached to the pump ,but I paid like $1300 dollars for it so thought I paid for cleaning as well 4be9b74bc7e3aa308f6f9c21c47f7509.jpg333b9bd461af6b403d0c554a32418d74.jpga5f7e89c14e207a427bed3c64d785c01.jpg8f5f9aeba0a972cce1f263ee22fe5a84.jpg27c757311237533b749e4666d2242953.jpgb88e4d06ef44653c227983967b714b3f.jpg65b611ad6a7ed623ede5c317a14e333e.jpg
  • XR50T
  • Member For: 11y 11m 22d
Best to give Kev at Process West a call tomorrow. When I had my surge changed from a factory rail setup to a twin feed setup it was sent to process west and modified there.
Was thinking of that my self . If I would change to twin pumps I would say it would be worth it but think I might get the part send up and change it my self .can see that a twin pump would need a extra cradle so they sit side by side ,would have thoubgt they would fit it with that so that it would be easier to change from single to twin
  • XR50T
Perfect fit, have you checked to see if they line up with the turbo? The holes may be bigger to allow for variations
Yes will fit perfect now .if I would not have done this one side would have leaked as the stainless steel gasket would have not coverd one side .the cut out on the xforce dump was to much on one side which sux as there is only like 2 mm it will clamp to .not much for it to bite on so it does not blow out a gasket
8e361090f2c212edf3dce6d5b4771f7a.jpgab5aca8f99018f5a7a1d293ced8dbfd5.jpgc93c0f6fa55fbdfd416b75bb18d92f79.jpgthis way I know that they line up .with no spacer its imposible to see when bolting up . I could be wrong with that but one way to find out
  • Moar Powar Babeh
  • Member For: 19y 7m
Those spacers are going to sieze solid on the bolts from the heat cycling I'm afraid. You're going to wind up snapping bolt heads off when you try to disassemble the joint.
