matsfgxr6turbo Member 388 Member For: 14y 11m 28d Posted 27/06/14 03:06 PM Share Posted 27/06/14 03:06 PM wtf have you ever changed the coolant? Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 27d Gender: Male Location: In my house Posted 27/06/14 08:00 PM Share Posted 27/06/14 08:00 PM Try Risslone stop leak. You can get it from Super Crap Auto. It will fix the problem. I use it on a truck at work that had a annoying slow leak somewhere in the cooling system. Fixed the problem. Its about $60 but it works. Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 6d Gender: Male Location: adelaide Posted 28/06/14 04:39 AM Share Posted 28/06/14 04:39 AM Are you talking to me? Then yes this is what happens when coolant is on a hot block.. Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 10m 4d Gender: Male Posted 28/06/14 03:14 PM Share Posted 28/06/14 03:14 PM I would still retorque the head bolts a bit more than stock settings (yes TTY just do it ) or put studs in. That sort of leak seems to happen under boost rather than just normal driving. Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 6d Gender: Male Location: adelaide Posted 28/06/14 04:05 PM Share Posted 28/06/14 04:05 PM The studs cannot be retorqued as they are yeld once use Link to comment Share on other sites More sharing options...
Spoony Member 250 Member For: 14y 3m 23d Gender: Male Location: Brisbane Posted 29/06/14 09:19 PM Author Share Posted 29/06/14 09:19 PM Still hasn't moved a mm since then Nulon stuff, $12 or whatever it was a bottle. Coolant still looks green/same colour and clean. Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 6d Gender: Male Location: adelaide Posted 30/06/14 03:34 AM Share Posted 30/06/14 03:34 AM What did you use mate? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 7d Gender: Male Location: Perth Posted 30/06/14 04:03 AM Share Posted 30/06/14 04:03 AM Okay ive done some research and I stand corrected some addatives are ok but if you plan on keeping the car id do it properly im abiut to do the hesd on my fg turbo... 20140608_213937.jpgIf you are keeping the car fix it properly. Additives are a short fix but can introduce issues in the future. Link to comment Share on other sites More sharing options...
Spoony Member 250 Member For: 14y 3m 23d Gender: Male Location: Brisbane Posted 30/06/14 04:46 AM Author Share Posted 30/06/14 04:46 AM What did you use mate?http://www.nulon.com.au/products/Cooling_Systems/Radiator_Stop_Leak/#.U7DmY_mSx8EI'm trying to find the thread/discussion on another forum with the Nulon rep who basically explained it a being good for weeps and assured it wouldn't cause blockages in a system that's already clean.I'd also consider using this stuff. Flush/change it out after so can't really get caught in the system.http://www.supercheapauto.com.au/online-store/products/DynaGrip-Metallic-Seal-Tite-Radiator-Stop-Leak-250mL.aspx?pid=0468#Cross Link to comment Share on other sites More sharing options...
