Awd Territory Vibration
stew565
  • Member For: 20y 1m 27d
The most common issues are diff bushes, front and rear. Rarely is the '3rd' diff bush in the front replaced, on the drivers side. Also, the radius arm bushes cause problems, these should be replaced as well. Check out the upper control arm bushes and inner lower control arm bushes, if these are worn you'll get a pulsating while braking, typical of cars fitted with the larger brakes and Brembos. Rear problematic on FG Falcons. Then there's the usual centre bearing, the rubber joint between the trans and driveshaft and uni joints.
It could be a combination of all these items, a couple or one. You'll need to troubleshoot, throwing parts at it will usually lead to a fix.
Edited by Romulus
