  • Dropping a turd
  • Member For: 17y 6m 13d
Have you got the correct hose. There are a few types.
I just fitted one to Todds ute. Had no issues and it came from Repco. The bag has specific instructions
  • Member For: 14y 1m 19d
Pretty sure I have. The one they gave me "suits factory 18" wheels"
Just picked up another one from auto one. See how I go. The hoses look exactly
The same as the one that was on there previously
  • Moar Powar Babeh
  • Member For: 19y 7m 17d
Hoses are different (internally) fitting is the same. If you f'd up the thread on the hose the threads weren't aligned correctly.
Start the fitting by hand before clamping the hose down it should screw in by hand until the o-ring contacts the inner seat in the pump fitting.
Sooo finally I had a win. But after a lot of stuffing around!
The thread inside the pump was stripped a little and I couldn't get another one any where so I had to buy a new pump.
46D94A56-EF92-4DDC-A34E-3E5AC0C0C22F_zps
Love having it clean in the bay. Just need to get this crank seal sorted now.
5A716360-DF13-4A0D-9DCE-DCAC368E16D1_zps
  • Member For: 11y 6m 11d
Good to hear, make sure you use the right puller, shouldn't have to remove the radiator either, just the thermo fans
Edited by Spyathe
  • Dropping a turd
that's bad luck.
But at least its all good now.
