Engine Oil Leak Help
LazyBrennan
  • Member For: 14y 6d
Hello
Im having some issues with a oil leak in my engine bay. BF2 xr6T
DA618F13-D1C3-412A-B0A1-04DB5EB43777_zps
5C14648F-3E2E-4633-9B95-D760204D7941_zps
4E72DE2C-D791-4C45-92BF-4E7745B1DAC2_zps
F5FBC4B3-47FC-45AA-A224-0141320B6EF4_zps
Does this look like the timing seal or just alot of power steering fluid or maybe something else?
I had the timing seal replaced a little bit over a year ago by XFT so I wouldn't think it should be leaking yet?
I know its a fair job to replace but what exactly is involved? Sump have to come out? All the pulleys need to come off? Rocker cover off? Looks like there is a fair bit of oil on the alternator so be worth just changing that while its all apart =/
Any help would be greatly appreciated! Want to hurry up and get this sorted so I can do my E85 tune!
  • Member For: 21y 7m 23d
Could be Power Steer fluid coming from the shaft seal and being thrown around by the pulley. Something for you to check. I'd suggest giving it a good degrease and keep an eye on it to see where it's originating from.
Benny.
Edited by Benny
  • Member For: 17y 4m 19d
Isnt that the factory standard fitment front cover leak?
My last two B's have done it.
Carefull with the degreaser, it can cause corrosion to start up, my turbo waterfeed pipe is crappyrusty now since degreasing. Good excuse for more braided lines though I guess.
  • Member For: 11y 4m 27d
The diff?
More than likely crank seal mate, harmonic balancer would spread it everywhere, changed mine and pressure washed everything I could see, not a drop of oil anywhere now
  • Moar Powar Babeh
  • Member For: 19y 6m 5d
Benny.
I reckon this guy might be onto it. Looks like trans/power steering fluid to me and the shape of the spray pattern looks like it's originating from the back of the pump.
Thanks for the replies guys!
Going to be changing the high pressure power steering hose tomorrow. The original plazmaman air intake I had was pushing up against that steering hose so im guessing it may have something to do with it. Have a nizpro one now so all good.
Will let you know how I go. Going to be messy im sure haha.
Soooo... -.-
Repco brand parts are just as good as top brand names parts they said.... -.-
Ok so I jacked the car up, spend hours smashing it with degreaser ect. Got it looking Micky mouse. Took the old hose off, fitted the bottom part first. Then I went to fit the hose to the steering pump. All seemed good I started the car and it just pissed the new oil. The flicking bolt stripped it's self -.-
So now on my way to buy another hose.
Here's some pics of the damage before cleaning
EE71AEE8-6C8F-4712-9EA3-130DDDB0E44A_zps
Think the crank seal is a goner
66EFC328-0FF0-4EDA-8A87-5E06832E7B7C_zps
8F602E17-4523-4744-9DA7-3A7FD4DCB2B7_zps
