FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 3m 16d Gender: Male Location: In my house Posted 24/05/14 08:13 AM Share Posted 24/05/14 08:13 AM Wait for a dry day. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473606 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 7m 10d Gender: Female Location: SA Posted 24/05/14 08:33 AM Share Posted 24/05/14 08:33 AM Put snow chains on the tyres ... Works a treat Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473611 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 30d Gender: Male Location: Probably above atmospheric pressure Posted 24/05/14 10:47 AM Share Posted 24/05/14 10:47 AM 6 Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473639 Share on other sites More sharing options...
Z2TT Member 714 Member For: 12y 10m 28d Posted 24/05/14 12:29 PM Share Posted 24/05/14 12:29 PM (edited) Hi Mike it comes down to the tyres that you have, both front and rear are important for traction, and make sure you get a wheel alignment so camber is near neutral so the tyre has a good contact to the ground. Your going to have to try find a set that gives the best wet grip, I suggest reading online reviews to help you out once you begin trial and error, some tyres are very good in the wet and can make all the difference.I find my Michelin Pilot Super sports to be pretty impressive in the wet. You can play around with pressures too but with my specific tyres I didn't notice too much of a difference between 36 to 45 PSI, 40 PSI seemed to extract the most wet grip out of it, your results might vary though.To Begin, leave traction control on and do not put your foot flat to the floor on launches you will never get grip that way once you begin spinning it wont grip, with traction on if you give it too much gas you will either go sideways, or if the TRC is not quick enough to react, it will suddenly smash the brakes on and take all the power out. If you gradually give it gas with traction control on, it will do a good job at stopping you losing traction once getting on power. Then once you are used to it, you can try it without traction control. Be careful on the highway if you got a bit of power, you may get grip initially on wide open throttle, but once it shifts into the higher gears, it can begin to wheel-spin suddenly. And also be careful as you reach 3000 rpm, you are going to have to learn to take your foot off the gas just the right amount to modulate the power correctly. Edited 24/05/14 12:40 PM by Z2TT Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473658 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 9m 22d Gender: Male Posted 24/05/14 12:29 PM Share Posted 24/05/14 12:29 PM Within the limits of the law for the sole purpose of going from point 'A' to point 'B' Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473659 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 24d Gender: Male Posted 24/05/14 12:53 PM Share Posted 24/05/14 12:53 PM Driving around with a couple of fat chicks in the back seat helps 3 Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473661 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 4d Gender: Male Location: Zombie Birdhouse Posted 24/05/14 10:50 PM Share Posted 24/05/14 10:50 PM I keep them in the boot Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473692 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 24d Gender: Male Posted 25/05/14 04:31 PM Share Posted 25/05/14 04:31 PM Too skinny if you can squeeze both in the boot Link to comment https://www.fordxr6turbo.com/forum/topic/88310-what-would-be-the-best-way-to-drive-fg-turbo-in-wet/page/3/#findComment-1473868 Share on other sites More sharing options...
