  • RNS10S
  • Member For: 18y 10m 5d
  On 22/05/2014 at 11:46 AM, ratter said:
no 6235 on BF's yet mate, we used the supplied actuator as the owner supplied it all himself, BF to FG should make no difference though
Yeah you'd think so but there are now 2 BA/F's that I know that have this turbo and both have had the same issue.
Both tuners have had no issues with this turbo on FG's
Spiro has done 4 or 5 now and apart from mine there was no issue with keeping boost down even as low as 14psi.
My port job was done at Autotech 3 years ago, we have never had issues controlling boost before we fitted this turbo.
  • Member For: 13y 10m 11d
Did you use a ruler to rule those boost and afr lines :)
Sct911 you have the answers to the questions your asking. Just remember zf zf zf zf! No good going for gold on fuel system then pop goes mr zf.
  • Like 2
  • Member For: 19y 7m 30d
  On 21/05/2014 at 12:25 PM, pac23 said:
Hi all,
I am seriously considering the next step with my fg.. Current 325rwkw with the standard turbo and I want more..
I am looking at kpm 460 and approx 1000cc injectors?
Any suggestions to the best fuel upgrade as I currently only have a slight upgraded walbro intank..
I wanna put a precision 6235 and have both 98 and e85 tunes power approx 420-450rwkw from what I have heard.. Car is fg with a zf tuned..
Hi
I would suggest the following
Streetfighter Twin Intank 1000hp fuel system coupled with KPM1500cc Injectors
Includes
Twin Intank pumpS/ NO Surge module
High Flow Fuel Pressure regulator
Plug and Play wiring / relay kit
This system will support approx from standard to 600 rwkw on your vehicle.
The idle qualities will be as good/better than standard with tuning while the fuel delivered will be cool dense at correct system pressures .
This is vital to support ultimate power and performance from your engine.
This package is a no fuss no nonsense solution that is engineered to work perfectly on your vehicle.
Fitmant time is approx 1.5 hours and all components are direct replacemant to OEM.
Edited by KPM Motorsport
  • Member For: 13y 1m 26d
What would be the max rwkw capababilities of you single pump system as I don't want much over the 420 mark eflex now as the gearbox will be saying bye bye if I go to crazy and definitely can't afford the upgrade on that aswell right now..
The price difference between single and twin pumps is worth saving on too if I don't need it
  • Idiot Member
  • Member For: 15y 5m
Kpm, the fitment of your twin intank setup does it just use the factory fuel lines and fuel rail?
I ask this because im in the position with one 044 and surge tank now and to go further its another pump, fuel rail and lines etc. A lot easier if I get rid of it and just fit intank setup.
Yes.
There is no reason for fuel line or fuel rail changes with a correctly engineered set up.
We supply the following for a correctly operating system.
  • Twin Intank Module is a direct replacemant fit that clicks directly onto the standard fuel lines.
  • Fuel pressure regulator is a direct replacemant High flow unit that is a direct fir replacemant for your standard unit.
  • Wiring/relay is a designed for the extra currant needed and is a direct plug into your existing wiring loom.
This set up wii perfectly support 1000hp with cool dense fuel with No Surge , smells or noise.
  • Member For: 12y 2m 18d
KPM's twin pump module is a simple yet great piece of engineering... I have just installed one and couldn't be happier, no surge, no smells and no noise..
Currently around 400rwkw on e85, but gtx3582
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 21d
Remember peppy your hour count is well underway, hope u have a way of telling when time is up, hope for you is not rodney saying hello
