  • RNS10S
  • Member For: 18y 10m 3d
  On 22/05/2014 at 12:13 AM, ratter said:
not disputing the 490 on 85 but where does that number come from?
we did one a few weeks back on a manual only on 98 and seem to be around the 420 mark before running out of puff, the car had cams in it which should have helped the top end but that was it, on paper it is a 700hp turbo, which I would estimate to be between 409-420 rwkw.
How much boost Mick?
We couldn't get boost below 21-22psi so ended up fattening up the afr's to 11-1 and with very little timing it made 410rwks on 98
Edited by rednose
  • Waiting for the 1st N/A 12!
  • Member For: 17y 4m 8d
Not sure why Joe would say that Ham.
Edited by Vevapower
Probably was talking about the challenges in controlling boost with. them.
  • Member For: 12y 7m 13d
that would be it !
mate, you would have been in GTX and precision equipped cars, is it a much of a muchness or can you tell a big difference?
Edited by sct911
  • XR50T
  • Member For: 12y 1m 18d
Dunno why people are saying theres issues with the DW 300s.
The failures were when people made their own wiring harnesses with undersized cables and the pumps pretty much instantly burnt out.
I've been using the PW twin DW300 pump kit with Kevs harness for 10k km with no issues on Eflex.
  • RNS10S
  On 22/05/2014 at 5:42 AM, sct911 said:
Joe was mentioning to me the other day that the pt6235 is a bit iffy on 98 , eflex is the solution :D
damn precision nerds made the turbo too efficient
I reckon use a garret actuator and she'll be fine.
I think the problem is the actuator supplied with the turbo, just get it without the actuator and get Joe to use a garrett one.
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 2m 22d
Pw surge x 2 460s (submerged surge) 1000cc kpm injectors fuel reg is what I have. Std intank and fuel rail.. makes 415rwkw on 98 @ 18psi and 470 19-20psi on e85.. I use a turbosmart 12psi actuator
