rednose RNS10S Donating Members 2,229 Member For: 18y 6m 11d Gender: Male Posted 22/05/14 12:07 PM Share Posted 22/05/14 12:07 PM no 6235 on BF's yet mate, we used the supplied actuator as the owner supplied it all himself, BF to FG should make no difference thoughYeah you'd think so but there are now 2 BA/F's that I know that have this turbo and both have had the same issue.Both tuners have had no issues with this turbo on FG'sSpiro has done 4 or 5 now and apart from mine there was no issue with keeping boost down even as low as 14psi.My port job was done at Autotech 3 years ago, we have never had issues controlling boost before we fitted this turbo. Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 19d Gender: Male Location: OZ Posted 22/05/14 02:48 PM Share Posted 22/05/14 02:48 PM Mick, that's the sexiest dyno graph I've seen in a long time!! 2 Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 6m 16d Gender: Male Posted 22/05/14 03:22 PM Share Posted 22/05/14 03:22 PM Did you use a ruler to rule those boost and afr lines Sct911 you have the answers to the questions your asking. Just remember zf zf zf zf! No good going for gold on fuel system then pop goes mr zf. 2 Link to comment Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 4m 5d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 22/05/14 11:24 PM Share Posted 22/05/14 11:24 PM (edited) Hi all,I am seriously considering the next step with my fg.. Current 325rwkw with the standard turbo and I want more..I am looking at kpm 460 and approx 1000cc injectors?Any suggestions to the best fuel upgrade as I currently only have a slight upgraded walbro intank..I wanna put a precision 6235 and have both 98 and e85 tunes power approx 420-450rwkw from what I have heard.. Car is fg with a zf tuned..HiI would suggest the followingStreetfighter Twin Intank 1000hp fuel system coupled with KPM1500cc InjectorsIncludesTwin Intank pumpS/ NO Surge moduleHigh Flow Fuel Pressure regulatorPlug and Play wiring / relay kitThis system will support approx from standard to 600 rwkw on your vehicle. The idle qualities will be as good/better than standard with tuning while the fuel delivered will be cool dense at correct system pressures .This is vital to support ultimate power and performance from your engine.This package is a no fuss no nonsense solution that is engineered to work perfectly on your vehicle.Fitmant time is approx 1.5 hours and all components are direct replacemant to OEM. Edited 22/05/14 11:36 PM by KPM Motorsport Link to comment Share on other sites More sharing options...
pac23 Member 103 Member For: 12y 10m 1d Gender: Male Location: Sydney Posted 23/05/14 10:53 AM Author Share Posted 23/05/14 10:53 AM What would be the max rwkw capababilities of you single pump system as I don't want much over the 420 mark eflex now as the gearbox will be saying bye bye if I go to crazy and definitely can't afford the upgrade on that aswell right now..The price difference between single and twin pumps is worth saving on too if I don't need it Link to comment Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 1m 6d Gender: Male Location: Muswellbrook, NSW Posted 31/05/14 12:15 AM Share Posted 31/05/14 12:15 AM Kpm, the fitment of your twin intank setup does it just use the factory fuel lines and fuel rail?I ask this because im in the position with one 044 and surge tank now and to go further its another pump, fuel rail and lines etc. A lot easier if I get rid of it and just fit intank setup. 1 Link to comment Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 4m 5d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 01/06/14 01:08 AM Share Posted 01/06/14 01:08 AM Kpm, the fitment of your twin intank setup does it just use the factory fuel lines and fuel rail?I ask this because im in the position with one 044 and surge tank now and to go further its another pump, fuel rail and lines etc. A lot easier if I get rid of it and just fit intank setup.Yes. There is no reason for fuel line or fuel rail changes with a correctly engineered set up.We supply the following for a correctly operating system.Twin Intank Module is a direct replacemant fit that clicks directly onto the standard fuel lines.Fuel pressure regulator is a direct replacemant High flow unit that is a direct fir replacemant for your standard unit. Wiring/relay is a designed for the extra currant needed and is a direct plug into your existing wiring loom.This set up wii perfectly support 1000hp with cool dense fuel with No Surge , smells or noise. 1 Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 10m 24d Gender: Male Location: Liverpool Posted 02/06/14 08:19 AM Share Posted 02/06/14 08:19 AM KPM's twin pump module is a simple yet great piece of engineering... I have just installed one and couldn't be happier, no surge, no smells and no noise..Currently around 400rwkw on e85, but gtx3582 Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 7m 20d Gender: Male Location: Perth, SOR Posted 02/06/14 10:32 AM Share Posted 02/06/14 10:32 AM ^^^What sort of price we talking? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 27d Gender: Male Location: Adelaide Posted 02/06/14 10:40 AM Share Posted 02/06/14 10:40 AM Remember peppy your hour count is well underway, hope u have a way of telling when time is up, hope for you is not rodney saying hello 1 Link to comment Share on other sites More sharing options...
